How did you wire YOUR aftermarket seat heaters?? Looking for ideas....
Discussion in '2.5 Gen Tundras (2014-2021)' started by graves037, Oct 27, 2019.
  1. Oct 27, 2019 at 6:32 PM
    graves037
    graves037 [OP] New Member
    Michael
    Pea Ridge AR
    16 Tundra SR5
    3" readylift, trail grapplers on 20" rockstar II's, truxedo lopro, lund bull bar, 20 & 30 in lightbars, tint, LEDs
    Looking for some ideas on how to wire and what to tap into for my aftermarket seat heaters....mine’s a 19 crewmax.......fire away!!!!
  2. Oct 27, 2019 at 9:27 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The heaters have a LED switch light and power wire as well as a ground(3 wires). I twisted the two powers together and connected them to a fuse tap and used an empty slot on the fuse box under the dash. There's already a slot for seat heaters if you look at the fuse diagram and if you don't have factory heaters its empty. Easy peasy. Whatever slot you use make sure its enough amps to power your seat heaters by referencing the draw the factory states. Also make sure that the slot is not powered unless the key is in acc or on position. Also never put a higher amp fuse into a lower amp slot. If you don't have enough amp to run front and rear on one tap use two slots. you should have plenty of empty fuse slots.
    graves037[OP] likes this.
  3. Oct 27, 2019 at 9:29 PM
    Tundyfundy
    Bay Area, CA
    You could also tap into one of the factory 12v outlets except you run the risk of popping the fuse because the load would vary. Your better off dedicating a seperate circuit by using fuse taps and you dont have to splice your factory wiring at all!
  4. Oct 27, 2019 at 9:30 PM
    Tundyfundy
    Bay Area, CA
    I wired my aftermarket heaters both front seats and rear seats in my 2016.
  5. Oct 28, 2019 at 8:09 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Starting in 2018 there is no seat heater fuse on the SR5 fuseblocks under the dash.
  6. Oct 28, 2019 at 8:12 AM
    Tundyfundy
    Bay Area, CA
    Bummer to hear. No biggy though. I’m sure there’s plenty of fuse options after that. Now I know...
  7. Oct 28, 2019 at 8:14 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    So if you don’t mind me asking what seat heater are you using?
  8. Oct 28, 2019 at 10:22 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    I’m using Roadwire
  9. Oct 30, 2019 at 3:58 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Do you know off hand which wire to the 12v outlets is the power wire?
  10. Oct 30, 2019 at 4:08 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    Thank you
  11. Oct 30, 2019 at 7:12 PM
    Tundyfundy
    Bay Area, CA
    No but if there is a red wire then that's it
  12. Oct 31, 2019 at 9:18 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    Well after I took it apart, I realized what a stupid question that was.....each one has a red wire, and a black/white wire. Quite obvious lol
    Tundyfundy[QUOTED] likes this.
