How big is yours? Measure up!
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, May 15, 2019.
  1. Jan 6, 2026 at 6:38 PM
    #211
    Upshot Knothole
    Upshot Knothole This space for rent.
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I'll measure all of mine tomorrow when I'm in a nice dry parking garage. If I can I'll pull my bike rack off before hand to get a more accurate measurement.
  2. Jan 6, 2026 at 6:48 PM
    #212
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
    I’ve been beating the tar out of my new ATS springs. Originally they had a much higher arch to them, but i went wheelin last weekend and really worked them. Then loaded up a ton of firewood in the back a few days later. They now sit at 22.5”.
  3. Feb 3, 2026 at 2:24 PM
    #213
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Finally measured where it’s at with the stock, worn out springs. I know I’ve been saying this for years but 6112s are coming soon. It’s about time.
    Hub to fender:
    20.5 DF PF 21.5
    23 DR PR 22.75
    Ground to fender:
    34.5 DF PF 36
    37 DR PR 37
    Tire size is 265/75/16, measurements were taken with a full tank of gas. Nothing in the bed aside from the ~80lb bedcover.
    It’s clear that the drivers front spring is the most worn out, not only from measurements but because it bottoms out on every single bump. It’s gotten so bad that the bump stops are getting torn up.
    It’ll be interesting to see how much those numbers change once I put on 6112s. I’m planning on setting them to the lowest setting, maybe one clip up on the drivers side. The leafs seem to be in decent shape considering the mileage, I’ve never felt them bottom out even with ~900lbs in the bed.
  4. Feb 3, 2026 at 2:44 PM
    #214
    Tundraforever1
    Tundraforever1 Nobody rides for free
    2001 2WD AC 4.7l 2010 2WD CM Limited 5.7l
    Preloading only one spring may adversely affect handling/steering. Better to install a shim on the drivers side.
    shifty` and FiatRunner[QUOTED] like this.
  5. Feb 3, 2026 at 4:14 PM
    #215
    FiatRunner
    Jack
    Very true. We’ll have to see what the heights are after I install them. That said- anything has got to be better than the current setup. The drivers front spring is so shot that it simply rides the bump stop on sharp right turns. The whole truck keels forward and down.
  6. Feb 3, 2026 at 4:50 PM
    #216
    Upshot Knothole
    Thatchery
    PDX OR
    6112s specifically tell you to use different clips for driver and passenger sides. I have mine set to 5/3 with heavier rated springs and the truck sits level side to side.
  7. Feb 3, 2026 at 5:51 PM
    #217
    Tundraforever1
    Very interesting. I did not know that.
  8. Feb 3, 2026 at 6:18 PM
    #218
    shifty` Too bad it took bullets to give you an open mind
    I would add though, based on other member experiences, it sounds like offsetting the clips by 1, versus the 2 Bilstein recommends, seems to address the classic "Tundra Lean" we deal with up front for some folks. Maybe DC folks, I can't remember. They don't pay me enough around this place. I don't even get free beer!
  9. Feb 3, 2026 at 6:20 PM
    #219
    Tundraforever1
    I fail to see how it doesn't increase the possibility of adverse handling and steering though, but what do I know? I'm going to look into it tomorrow.
  10. Feb 4, 2026 at 10:17 AM
    #220
    Upshot Knothole
    Thatchery
    PDX OR
    The majority of the non symmetrical weight in these trucks is on the drivers side. Full tank of gas is over 150 lbs, plus the battery and the driver. Toyota put different springs on the passenger and drivers side front suspension, the aftermarket world isn't going to bother making two different springs for our trucks with that little difference, so it makes sense to make up the difference with preload on the springs. Adjusting preload for weight is standard practice on motorcycles with much more finicky suspension, having an extra quarter inch of preload on one of my front springs on my truck isn't going to bother me at all.
  11. Feb 4, 2026 at 10:30 AM
    #221
    Tundraforever1
    That makes sense. I get it. Physics and math is acceptable.
  12. Feb 20, 2026 at 10:23 AM
    #222
    Magnum099
    Magnum099 New Member
    Huntsville, AL
    2006 Silver Tundra DC SR5 2WD
    2006 Double Cab SR5 2wd
    Just swapped the front shocks and springs yesterday from the factory Tokico.
    Rear Bilstein 4600 Shocks w/factory leaf springs (new shocks summer 2025)
    Front Bilstein 4600 Shocks w/OME 2883 springs (purchased assembled from 1st Gen Offroad w/new top hats & strut mounts)
    Raceline 958T Rogue 17x9 Wheels, -12 offset with Yokohama Geolandar G015 265/65R17 Tires.
    Before w/full tank of gas:
    Driver Front - 19.125 in.
    Passenger Front - 19.25 in.
    Driver Rear - 21.5 in.
    Passenger Rear - 21.5 in.
    After w/ appr. 1/2 tank of gas:
    Driver Front - 20.625 in.
    Passenger Front - 20.75 in.
    Driver Rear - 21.75 in.
    Passenger Rear - 21.75 in.
    The front has already settled in a good bit after just 2 short drives and sitting overnight. Right off the jack stands yesterday, they were measuring ~21.25 in the front on my not-level driveway.
    As it sits now:
  13. Mar 3, 2026 at 1:38 AM
    #223
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    +Front Driver-22.25"
    +Front Pass : 22.5"
    +Rear Driver : 23..25 "
    +pass Driver: 23..50
    2002 Tundra V8 RCLB 4x4- full tank, sliders, 200 Lbs toolbox
    -Eibacl sports on all corners. Fronts paired with Dobinson C30's 590 Lbs coil springs.. button clip
