Holy dirt, leaves and Nuts in Door
Discussion in 'Detailing' started by Les7311, Apr 15, 2017.
  1. Apr 15, 2017 at 5:03 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Picture spells a million words.
    Front bottom of both door panels
    Go check yours.
    trayday and ColoradoTJ like this.
  2. Apr 18, 2017 at 6:24 AM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    Interesting. have you done any CMC or removed the fender liner behind the wheel?
  3. Apr 18, 2017 at 8:14 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Just checked mine and they are both clean as could be.
  4. Apr 18, 2017 at 9:46 AM
    TheBeast The Beach
    I had the same in my honda civic that is parked in the street. Filthy
  5. Apr 18, 2017 at 9:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I hate finding my nuts in the door. :oops:
    This seems to be a somewhat recent discovery. There are other threads on it too. Mine wasn't too bad on my '11, but my neighbor's '07 had it worse. He's been off-road with his truck much more than I have with this one. I'm guessing that it's a combination of the larger items falling down from the base of the windshield at it's outboard edges and road debris filtering past the fender liners.
    TheBeast likes this.
  6. Apr 18, 2017 at 10:10 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I did the front radiator vents on my 911 a few weeks ago, think there was 2-3 lbs of debris
  7. Apr 18, 2017 at 10:44 AM
    Les7311
    Will have to next time around. The previous owner prob didn't know. That cavity was filled
  8. Apr 18, 2017 at 10:50 AM
    LML 3500HD
    Yep, pretty common issue. Debris collects up top by the windshield and go down from there. Mud gets packed inside pretty easy as well. Cleaned mine out a bunch on a factory 12' CM.
  9. Apr 18, 2017 at 10:55 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mice was squeaky clean. I haven't had it off road at all though.
