Hi guys I am a new member from California. I have a Toyota Tundra 2005 V8 4.7 2WD.
Discussion in 'New Member Introductions' started by A1P, Dec 4, 2021.
  1. Dec 4, 2021 at 10:27 AM
    A1P
    A1P [OP] New Member
    Arnoldo
    Toyota Tundra 2005 V8 4.7 2WD code P0418 on. Manual reads secondary air injection pump Relay A control circuit. My question is, what is that I need to replace and the part number I need. And if I could do any testing and troubleshooting prior to replacing any parts are there any specific procedures to pinpoint what is bad. Your responses will be very much appreciated, thanks in advance.
    None
    My 2005 Toyota Tundra V8 4.7 2WD Crew Cab Limited Edition gave me no troubles at all before the 2 cat converters and O2 sensors were stolen. I had all fixed at a mechanic shop and the installer tried to reset check engine light but he couldn’t. Initially when I connected the scanner, I had P0031, P0051 and P0418 codes. I replaced both upstream sensors and the first 2 codes have been cleared. Now the P0418 which calls for secondary air injection pump relay A control circuit is still there. My question is any suggestions on how to proceed troubleshooting the system since there are solenoids valves, vacuum valves, relays and wire harness involved that will trigger the same error code and if I go ahead to fix it myself what are the part numbers I will need to purchase for that specific truck. Thanks in advance guys for your responses.
  2. Dec 4, 2021 at 10:29 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  3. Dec 4, 2021 at 10:42 AM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal. I think there are threads on bypassing that system, someone who knows more will probably be able to get you a link or more info at least.
  4. Dec 4, 2021 at 1:20 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Dec 4, 2021 at 3:08 PM
    ZHUNTER
    ZHUNTER New Member
    North Georgia
    2020 Quicksand Tundra DC TRD
    Westin Winch mount tray w/ custom light bar, avs hood deflector, 3” lift, badlands winch w/ wireless remote, bed stiffeners, Toyota Predator steps, Husky Floor liners
    Welcome!
  6. Dec 4, 2021 at 5:27 PM
    Welcome from NY.
  7. Dec 4, 2021 at 7:18 PM
    Sunnier
    Sunny
    San Diego, CA
    Hi, Arnolda, welcome from SoCal as well!
    I suggest you start a new thread, not in this New Member Intro section. You’ll get a lot more knowledgeable eyes on it if the thread title reflects that you need help with repair ideas for a specific issue.
    A lot of us don’t read the new members threads regularly; I checked because you’re in my general area.
    alb1k likes this.
  8. Dec 5, 2021 at 1:16 PM
    2mchfun
    Welcome from OKC!
  9. Dec 5, 2021 at 6:00 PM
  10. Dec 6, 2021 at 6:08 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
