Hi guys can someone help me out my truck is having trouble to start at cold mornings
Discussion in '1st Gen Tundras (2000-2006)' started by 2003 tundra 4x4, May 2, 2019.
How can i fix this ?
  1. Gas?
    50.0%
  2. Sensors?
    100.0%
Multiple votes are allowed.
  1. May 2, 2019 at 6:59 AM
    2003 tundra 4x4
    2003 tundra 4x4 [OP] New Member
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    My truck is having trouble to start when the engine gets cold but i starts and runs fine when it heats up
  2. May 2, 2019 at 7:07 AM
    faviles
    faviles New Member
    2001 Red Tundra SR5 TRD
    Stock for now
    Coolant temp sensor?
  3. May 2, 2019 at 7:16 AM
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    I allready change the coolant temperature sensor and the temperature sensor basically both would it be timing?
  4. May 2, 2019 at 8:44 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    A better description of the problem would help.
    15whtrd and faviles like this.
  5. May 2, 2019 at 10:15 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    Weak battery?
  6. May 2, 2019 at 11:08 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Not much info given but first thing first scan the vehicle for trouble codes, battery and starter load test, clean throttle body check data on ECT when cold and hot check and clean MAF just a couple things that come to mind. Once I had a hard cold start on a 2000 Accord and it was a bad Bank 1 air fuel ratio sensor
    JohnLakeman likes this.
  7. May 3, 2019 at 5:09 AM
    Wisconsin Tundra
    Wisconsin Tundra New Member
    Patrick
    Wisconsin
    2013 Tundra crewmax
    Mine started doing long starts also. The computer was reading pump gas at 70% instead of 10%. Had it reflashed and it's good now.
  8. May 3, 2019 at 5:10 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    ECU controls the entire starting process, including enriching fuel-air ratio for cold start based on ambient temp. You have great suggestions thus far...sensors provide the only info the ECU has to work with. Scan for codes.
  9. May 11, 2019 at 7:48 AM
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    I have replace the battery fuel pump coolant temperature scensors the starder is still good
  10. May 11, 2019 at 8:44 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I had an issue with cold starts earlier this year. I ran a couple treatments of Seafoam through it and started using mid grade fuel. I haven’t had any issues since. The issue could definitely be a sensor or maybe dirty injectors. What exactly is it doing?
    Racingjohndeere55 likes this.
  11. May 11, 2019 at 8:49 AM
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    It takes a long time to start when the engine gets cold or its cold outside it stutters for a long time but it dosent start. Ive changed the spark plugs the coils coolant temperature sensor the engine temper sensor fuel pump ..but when the truck heats up it runs and starts like nothing
  12. May 11, 2019 at 9:03 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I’m not the most mechanically inclined, but that sure sounds like it could be a fuel to air issue.
  13. May 11, 2019 at 9:05 AM
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    But what could it possibly be ive replaced every main component that the truck needs to start its just weird do you think it could be the timing ?
  14. May 11, 2019 at 4:15 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Try cleaning Throttle Body then disconnect battery touch both positive and negative terminals together for 20 seconds start the car but make sure all accessories are off including a/c let it idle for 20 min so it can relearn
  15. May 11, 2019 at 4:19 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Coolant temp sensor have been common on Toyota’s being bad it can give false readings to the computer and going into a rich condition I know u have changed it but I been a tech for over 30 years and installed plenty of defected new parts
  16. May 12, 2019 at 9:16 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    Why so many 2nd and 3rd gens in here?
    :D
  17. May 12, 2019 at 10:22 AM
    Yotatech
    Yotatech New Member
    Try replacing the fuel pressure regulator they are great at causing an extended cold crank issue on your gen
    pickeledpigsfeet likes this.
  18. May 12, 2019 at 3:41 PM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
  19. May 12, 2019 at 3:55 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    2nd and 3rd graders still have 1st grade knowledge. :boink:
    bmf4069[QUOTED] likes this.
  20. May 12, 2019 at 4:07 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Wen u disconnect the battery and touch both positive and negative cables together for about 15 seconds it clears and drains the powertrain control module you do that after any repairs so it can relearn
  21. May 13, 2019 at 4:19 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    I always just d/c the negative and hold the brakes for 30 sec to drain it.
