Hey guys I’m having some trouble with my truck
Discussion in 'New Member Introductions' started by dmartin69, Apr 30, 2023.
  1. Apr 30, 2023 at 12:02 PM
    dmartin69
    dmartin69 [OP] New Member
    2000 Toyota Tundra 4x4 4.7, with over 150000 miles
    Took off stock exhaust and put on flow masters, put all new led light all around
    Hey guys I’m having to crank my truck two times every time the first time it dies then the second time it stays running I put a code reader on it and it says maf sensor, will that keep it from cranking up
  2. Apr 30, 2023 at 12:11 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    The sensor could be part of the problem but I don't think it's all of it. Start by replacing the MAF sensor and pulling the battery cable for a few minutes to reset everything. Then see if the problem comes back and run the OBD again.
    If you wanted to try one more thing before replacing the MAF sensor you could pull your airbox open and clean the sensor first to see if that will help. I'd also clean the throttle body at the same time since you'll be in there. If this doesn't work then replace the sensor. If that doesn't work then maybe it will be giving you new codes to work with.
    dmartin69[OP] likes this.
  3. Apr 30, 2023 at 12:41 PM
    dmartin69
  4. Apr 30, 2023 at 12:42 PM
    dmartin69
    Thank you we cleaned the maf sensor already and the throttle body and also put in new fuel pump
  5. Apr 30, 2023 at 12:46 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Replace the sensor and reset and see if that helps. Is there only 1 code coming up on the OBD?
  6. Apr 30, 2023 at 5:57 PM
    dmartin69
    It is pulling up one for o2 sensor
  7. Apr 30, 2023 at 6:18 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Up stream or down? Usually can't correct those by cleaning. Did you possibly had bad fuel?
  8. Apr 30, 2023 at 6:36 PM
    dmartin69
    I can’t remember I’ll have to read it again tomorrow thank you
  9. Apr 30, 2023 at 8:42 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. May 1, 2023 at 2:36 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you replace the MAF make sure and get a Hitachi MAF from a reputable source. That's the OE supplier for that part.
  11. May 1, 2023 at 3:41 AM
    Welcome from NY.
  12. May 2, 2023 at 4:41 PM
    dmartin69
    It’s pulling up all of the o2 sensors, but surely that would not keep it from starting on the first try would it, it always starts on the second try and stays running
