Hesitant to turn over and P0335/P0340
Discussion in '1st Gen Tundras (2000-2006)' started by Zach_795, Nov 19, 2022.
  1. Nov 19, 2022 at 6:35 AM
    Zach_795
    Zach_795 [OP] Master Apprentice
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k
    Went out to start my 02 this morning, (27 degrees). Would not turn over. It has sort of done this before where you turn the key and it hesitates for about a second or two then cranks over and starts right up. But today it wasn’t having it even after holding the key for 10 seconds. So I went and got my battery charger and ran the 55A engine start option. Truck started right up. Also popped the check engine light, P0335 and P0340, (cam and crank position sensor, respectively). Drove 25min 20miles to work no problems running fine. Any ideas?
    Edit: When I got to work I unhooked the negative battery cable. Went out and hooked it back up at lunch, started with about 1/4 second hesitation and the codes went away.
  2. Nov 19, 2022 at 6:41 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    time for a new battery
    Aerindel and Jack McCarthy like this.
  3. Nov 19, 2022 at 11:42 AM
    shifty` We call it “riding the gravy train”
    No brainer: Go to any chain auto parts store. Ask them to test your battery. Chances are it's dying.
    If not, come back. Definitely have other thoughts. Start with the easiest and free diagnostic first, given the 'cold af weather' element here, it screams bad battery.
    Aerindel likes this.
  4. Nov 19, 2022 at 1:09 PM
    blenton
    blenton New Member
    I second the battery. Pretty simple fix.
  5. Nov 19, 2022 at 3:50 PM
    Aerindel
    Aerindel New Member
    Montana
    Bad battery.
    Bad battery cables.
  6. Nov 19, 2022 at 4:04 PM
    w666
    Maryland
    I only know this because a similar thing happened to me the other day. I got in my truck, turned the key, and it went "click" :(
    I had just been reading all the starter related threads here, and immediately jumped to the worse case scenario. I started checking relays, fuses, and following all the diagnostic threads. Then I came upon the divine wisdom from @Shifty ...."it's almost never the starter!".
    I tightened a lose negative terminal, clipped on my jump pack and it started right up. Took a ride to batteryland and found that that I had 3 years (and two days) on my 3 year battery. Marginal battery combined with a poor connection equals failure. Now I have a new 5 year battery, and new cable ends.
    Turns out the problem was just that I had too much money! But the battery guy assured me I'd come to the right place, and relieved me of ~ $170.
    bmf4069, shifty` and Zach_795[OP] like this.
  7. Nov 19, 2022 at 8:01 PM
    "It's almost never the starter"
    "It's never the fuel filter"
    Words to live by with 1GT.
  8. Nov 26, 2022 at 5:55 AM
    Zach_795
    Went to Interstate and got a brand new MTP-27F and now she starts like a champ no hesitation
    w666 and shifty` like this.
