HELP
Discussion in 'Suspension' started by SuperSport7755, Apr 13, 2018.
  1. Apr 13, 2018 at 2:52 PM
    SuperSport7755
    SuperSport7755 [OP] New Member
    Michael
    So. Cal
    2016 toyota tundra SR5 TRD
    wheels and tires
    Hey guys back again. 2016 tundra So I have the bilstein 5100’s in on the rear. I about to do the front. I have the bottom nut and bolt out and have all four nuts lose on the top. I haven’t touched the middle nut on the top for the compression of the coil. Just to be safe tho, can I remove the strut assembly and then use the compressor to compress the springs? Please advise ASAP
  2. Apr 13, 2018 at 5:17 PM
    TOTU17
    TOTU17 New Member
    What compressor ?
  3. Apr 13, 2018 at 5:18 PM
    TOTU17
    TOTU17 New Member
    And yes that is the safest way to do it. But the top middle nut is to hold the spring
  4. Apr 13, 2018 at 5:22 PM
    SuperSport7755
    Michael
    So. Cal
    wheels and tires
  5. Apr 13, 2018 at 5:39 PM
  6. Apr 13, 2018 at 5:41 PM
    TOTU17
    TOTU17 New Member
    That will work
  7. Apr 13, 2018 at 5:42 PM
    TOTU17
    TOTU17 New Member
    Hopefully they are 2 one for each side of the spring
