Help with the Nav Display?
Discussion in 'Audio & Video' started by Yorkwagon66, Jan 21, 2020.
  1. Jan 21, 2020 at 2:02 AM
    Yorkwagon66
    Yorkwagon66 [OP] New Member
    Kennesaw Ga
    2018 Tundra Limited CrewMax
    Hey all!
    I have a 2018 Tundra Limited Crewcab TRD 2WD
    Apparently the display will split into 2-3 screens showing the right half as Navigation, the others on mine are the audio and phone number quick select.
    Even when using the navigation, the display goes back to the 3-way split screen after a few seconds. I’ve found the setting where you can make changes to what is displayed, but can’t final a way to display the Navigation in full screen when being used. I want to see the navigation details/map in full screen when using it. Can I do that? If so, how? I’m old and need the bigger display.
    Thanks!
    Cowboy Cadillac and Y0TA PR0 like this.
  2. Jan 21, 2020 at 5:09 AM
    I think if you just touch the map it will expand to full screen.
    Y0TA PR0 likes this.
  3. Jan 21, 2020 at 5:12 AM
    Doxiedad
    Doxiedad New Member
    James
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    On my 16 4Runner when I used the factory Nav I could touch the Nav portion of the screen and it would take over full screen until I hit the home button on the dash. I haven't used the built in nav on my Tundra but once, and I seem to remember it being the same way.
  4. Jan 21, 2020 at 5:15 AM
    Yorkwagon66
    Kennesaw Ga
    Thanks for the input but when I touch the map while using navigation, it does go to full screen, but then after a few moments, it resets to multi screen again.
  5. Jan 21, 2020 at 5:21 AM
    Doxiedad
    Doxiedad New Member
    James
    Try this:
    Press APPS button to left of Navigation screen
    Select SETUP
    Select GENERAL
    Scroll down (on right) and UNcheck AUTO RETURN TO HOME SCREEN.
    Y0TA PR0 and Yorkwagon66[OP] like this.
  6. Jan 21, 2020 at 5:23 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    There's no option for full time map screen. It will always default back.
  7. Jan 21, 2020 at 5:35 AM
    Doxiedad
    Doxiedad New Member
    James
    See my post above. I remember changing this on my 4Runner and it worked. It stayed on whatever you selected, Nav, Audio, Phone, you had to manually hit the Home button to go back home.
    I don't know if the Entune in the Tundra is the same, but for a 18 Tundra it should be the same.
    Yorkwagon66[OP] likes this.
  8. Jan 21, 2020 at 5:36 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If you find the option, let me know cause I've never seen it.
  9. Jan 21, 2020 at 5:38 AM
    Yorkwagon66
    Kennesaw Ga
    Thanks Doxidad! I think that worked. Why didn’t they put that control function under “Display”!
    I’m also trying to figure out how to select avoid/not avoid HOV and toll lanes for specific trips or as a general preference.
    Thanks again so much for your help! I bought this Tundra in September 19 and this display thing has been a source of frustration the entire time.
    Doxiedad likes this.
  10. Jan 21, 2020 at 5:45 AM
    Doxiedad
    Doxiedad New Member
    James
    Awesome. Glad it worked.
    Try this for toll roads
    How do you set the navigation to "Avoid Toll Roads" etc.? Touch the Apps button on the dash, then select "Navigation", then "Options", then "Edit Route". Then in the "Preferences" you can touch "Toll Roads" to toggle On or Off. To avoid Toll Roads you want it Off (the indicator NOT illuminated).
  11. Jan 21, 2020 at 5:45 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Mine is unchecked and still defaults back to full screen..
  12. Jan 21, 2020 at 5:48 AM
    Doxiedad
    Doxiedad New Member
    James
    So with it unchecked it still goes back to your home screen with the 3 displays?
    hmm I don’t know. It worked on mine. Sorry man
  13. Jan 21, 2020 at 5:50 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I can change from 2 or 3 displays but when using the Navigation it will not stay on full screen.
  14. Jan 21, 2020 at 5:54 AM
    Doxiedad
    Doxiedad New Member
    James
    Yeah I’m out of ideas. I only know of the one way to disable automatic home.
    jeremyd[QUOTED] likes this.
  15. Jan 21, 2020 at 6:23 AM
    Yorkwagon66
    Kennesaw Ga
    Doxiedad’s display instructions worked for my tundra. And thanks also for the help on HOV settings. I’ll try that.
  16. Jan 21, 2020 at 6:40 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Just confirming, So when you unchecked "return to home" your screen will stay on full screen when using the Navigation ?
  17. Jan 21, 2020 at 5:20 PM
    Yorkwagon66
    Kennesaw Ga
    What Doxiedad said worked for me. When you first crank up, it will be split. Touch to map and it will go full screen and stay that unless you select <Home> Or until you turn the engine off. Of course it may go off if you make/receive a call. I haven’t tried that yet.
    Thanks again to Doxiedad.
