Help with brake shudder
Discussion in '1st Gen Tundras (2000-2006)' started by 1xloader, May 23, 2018.
  1. May 23, 2018 at 5:26 PM
    1xloader
    1xloader [OP] New Member
    Had brake shudder problem, found one caliper not traveling on one side, 1 new pad, 1 almost gone. Anyway, new calipers and rotors (120,000 mi so why not) still have brake shudder. Not trusting store bought stuff, put on brembo caliper, pads, summit rotors slotted/dimpled. Still have shudder problem when braking. Checked back brakes, not bad but like say, alot miles so new drums and brakes. Still brake shudder. Front end tight, new wheel bearings and shafts 10,000 miles ago. New sway bar bushings, tires balanced good and lined up. Rack and pinion seem ok, A frame bushings not new but i've seen worse. Adjusted back brakes, applied the EM brakes at slow speed no real issue there...runningout of ideas..contemplating looking at the electronic metering valve but not wanting to get that far into a computer control (assume it computer control)..anyway...any body else solve this problem yet?
    Black Wolf likes this.
  2. May 23, 2018 at 5:36 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    No help to the issue, but Welcome to the party!!
  3. May 23, 2018 at 5:40 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada, sorry i cant help.
  4. May 23, 2018 at 7:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
    Wheel balance, bent wheel?
    mudslinger79 likes this.
  5. May 23, 2018 at 8:00 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sorry about your issue. Welcome from Colorado
  6. May 23, 2018 at 8:08 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  7. May 23, 2018 at 10:00 PM
    Welcome from Texas, hope it gets resolved
  8. May 24, 2018 at 3:58 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    When you say brake shudder, what exactly is happening? Not being a smart -ss just a little more information would be helpful. Did you torque all hard ware to spec? Wheels torqued to spec? Proper brake pad rotor break in? Aftermarket wheels/tires? Control arm bushings? Front brake lines collapsed internally/twisted? Just a lot of different things to look at.
    -Jason
    15whtrd likes this.
  9. May 24, 2018 at 12:34 PM
    1xloader
    you're not being smart guy...sometimes obvious gets missed, no, still have factory rims, I like to torque all lug nuts, brake hardware, etc, bushing factory with 120,000 miles on them..like I say, thery're not new but i've seen worse with no problems..brakes activate ok when bleeding for the new calipers, and i checked for binding etc...lines seem to be alright...shudder only when applying brakes, i usually hit them briefly, let off, then hit them 1-2 times for normal driving..habit of mine, ....I have the needle bearing wear issue in the front drivers side pumpkin toyota's have...doing that next...we'll see.
  10. May 24, 2018 at 2:59 PM
    koditten
    koditten New Member
    That was my 1st thought too. The needle bearing issue is noticed most when slowing down to an almost stop.
    Watt maker likes this.
  11. May 24, 2018 at 3:25 PM
    1xloader
    Thanks, I've found out that's not uncommon...guess I'm one of the lucky ones it lasted this long...ordered the ECG bearing , next break form work we'll change it...love the truck otherwise, Bought it new in '03...my first new vehicle.....rino liner and undercoated soon as got it home....thanks all for feedback...
    NewImprovedRon and Leo's first like this.
  12. Jun 6, 2018 at 5:06 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    Not to thread hi-jack but whats the needle bearing issue?
  13. Jun 6, 2018 at 5:56 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  14. Jun 6, 2018 at 5:58 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Welcome from CO! :popcorn:
  15. Jun 6, 2018 at 5:29 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  16. Jun 8, 2018 at 4:26 PM
    1xloader
    Re: lady wolf, the needle bearing issue is more for the tacoma, but on the driver's side, front diff, the cv axle support bearing inside the diff, this needle bearing will get early wear and allow the cv shaft to slop around and appear loose even when new...some tundra's get it, ECG has a replacement solid bearing....I put one in mine, it really does good job of taking slop out of the cv shaft, but didn't cure my braking shudder completely...more to come..
    Leo's first likes this.
  17. Jun 8, 2018 at 4:42 PM
    l3LUEFALCON
    l3LUEFALCON RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    Take your spare out, and put it on one wheel after another and drive around on it. After all the stuff that you did. It seems like it is either a bent rim.... or, and I hope not, your master cylinder. But I could be wrong.
  18. Jun 8, 2018 at 4:54 PM
    1xloader
    yeah, swapped out/front /rear wheels/...not the spare though...I was also wondering about the metering block on the master cyl....maybe next few days off.....thanks all for the info....If i get it i'll post it for others..thanks.
  19. Jun 9, 2018 at 8:42 PM
    garnaz
    garnaz New Member
    Need to check your frontend for play in parts. Bad tierod can cause this, bad rack bushings and bad brass bushing in rack and pinion can all cause this. Along with warped rotors
    When checking frontend if you get movement at inner tierod make sure it is inner tierod and not the rack brass bushing.
  20. Jun 10, 2018 at 2:13 PM
    1xloader
    been through the front end...mostly new stuff all round...rack and pinion and a frame bushings are on the suspect list, original 125,000 miles...
  21. Jul 17, 2018 at 8:34 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Did you replace your rotors and drums? You can check if it's caused by the drums by using the parking brake while coasting around 40mph. If you feel the shutter than it's the drums. If not it's coming from the front end.
  22. Jul 17, 2018 at 10:16 AM
    BestGen
    BestGen Free Kyle!
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Sounds like warped rotors.
  23. Jul 17, 2018 at 12:16 PM
    Professional Hand Model
    Hand Protectors
    I had warped rotors since 2004 up until a few weeks ago when they were replaced. Didn’t notice they were warped until coming to a slow down at slow speed you could feel the warped parts grabbing unevenly. Just dealt with it as it was no big deal. No shuddering just a slight grab grab grab at 10 to 0 mph slow to dead stop.
  24. Jul 21, 2018 at 7:09 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    If it is happening when your almost completely stopped it could be an abs sensor issue .
  25. Jul 21, 2018 at 7:14 AM
    Hand Protectors
    True. Went back and read this entire thread again. OP wasn’t specific on speeds of when problem occurs. The ABS could be loose or disconnected. Causing the problem when slowing down.
  26. Jul 25, 2018 at 4:11 PM
    Scottd51
    Scottd51 New Member
    2002 Tundra V-8
    Running boards
    You have to get the rotors with the slots and or holes in them, makes a big difference; I get a little vibration going down hill but not bad.
  27. Aug 12, 2018 at 8:50 AM
    flyfisher
    flyfisher Member
    David
    Sunnyvale, CA
    2005 Tundra SR5 Double Cab 4x4
    Had exact same problem. Returned aftermarket rotors for another pair thinking they were defective. Second pair had same affect. Returned them and bought OEM Toyota. Problem solved. Go figure!
  28. Aug 12, 2018 at 11:14 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    :crapstorm:
    He changed rotors already. All his front end joints seem okay and swapping rims front to back hasn't made a difference.
    Play in upper arm or lower arm bushings maybe?
    I think there gremlins have taken refuge in your truck and they like going fast. Whenever you slow down they kick your tires as a form of protest.
    Need to know stuff likes this.
  29. Aug 12, 2018 at 11:21 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Welcome from CO.
  30. Aug 16, 2018 at 10:55 AM
    1xloader
    ..ok finally solved (50 miles worth anyway) brake shudder. it usually showed up inside 1-2 miles before. after all the changes up front, the last set of turned rotors with Toyota pads, along with the rack/ pinion /sway bar bushings fixed the front...this was after slotted rotors/brembo pads, front diff cv shaft support bearing changed with ECG solid bearing,alignment/balanced, did NOT help any.....
    ...then, still had decent shake in the back, ( used the EM brake method to check this.) Had summit racing drums on with generic shoes (after some miles the back vibration got considerably worse. Bought Toyota shoes and was going to have drums turned as the cheap shoes had "shined" the drums. Local place trashed the drums while turning. The new drums they gave me in place of were worse. Bit the bullet and ordered Toyota drums.
    Problem is completely solve so far.
    Moral of the story I guess is not all Toyota parts play well with generics. My truck is 2003 and some of the parts were changed in mid-year...you can give them that info, but it doesn't always mean you get what you need. The rear
    vibration was probably self induced by me trying to change out non compatible stuff. The inside diameter of all drums is not the same. This means that if there is any excess shoe material, or if it is not centered, the contact points can change with the diameter of the drum...round is round does not always compute. In the old days when you could accidently switch long shoe/short shoe gives the same effect as the upswing of the drum "drags" on the extra pad material of some generic shoes. If you didn't have OEM pads to start with you may not have anything to compare it too....anyway.....thanks for the ideas people...hopefully won't have to need bailed out for awhile now......
    mtntop and Casper421 like this.
