Help wiring amber hood bulge on 2019 w/ halogen and led DRL
Discussion in 'Lighting' started by IowaGuy, Feb 1, 2023.
  1. Feb 1, 2023 at 9:35 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I searched and posted in a couple of old threads about how to wire some amber lights into my hood bulge and the more I ask the more confused I get as to how I should do this. How did you do yours?
    I have a 2019 with halogen headlights and the LED DRLs. I would like the amber bulge lights to be on with the DRL's. The issue I am running into is that the DRL's seem to have a high and low side depending if the headlights are on or not. There is a purple + and a Red+ for the high/low DRL's.
    I dont think I can connect both the high/low DRL's to the new bulge LED's without causing issues. I wonder if I could put in a relay and have the high/low trigger it or if that would feed back as well?
    If not then how about putting in a one-way diode so that they could not feedback to one another?
    Other ideas are just to wire in a tap-a-fuse to the IGN somewhere so they are on when the ignition is on. Or tap them into the taillight fuse under the dash
    My headlights
  2. Feb 1, 2023 at 9:36 AM
    Taco-Spike
    Two Trucks
    Low beam or Tail is what I'd do.
    or run a separate relay and have it on it's own switch
  3. Apr 2, 2023 at 9:11 PM
    basicSR19
    basicSR19 New Member
    Jacksonville, FL
    @IowaGuy Did you ever figure it out? I have the same headlights on my 2019 sr, and I want the amber drl's like the older tundras
  4. Apr 3, 2023 at 5:45 AM
    IowaGuy
    In Process
    I finally just ended up using a tap-a-fuse and putting them on the IGN fuse in the under the hood fuse block. They are on all the time this way and no fuss. I ran the wire for them through the hood and used some wire loom and that was also easy and clean. Oh, I also ended up using amber LED button lights. I took the grill bulge off and and drilled through the plastic mesh and wired them together in series.
    basicSR19[QUOTED] likes this.
  5. Mar 16, 2024 at 4:13 PM
    tgbusche22
    tgbusche22 New Member
    Taber
    2019 Tundra 5.7 liter
    I have the same light and set up as you do. Mounted the light strip behind the hood bulge and ran the wire. I just need to know exactly which wires I tap into for my DRL’s. Don’t want to cut any wire until I know exactly how it should be done. Can you help me out?
