Help W/ Opening Doors W/O Key In (Inside car)
Discussion in 'New Member Introductions' started by Emmylou26, Apr 14, 2023.
  1. Apr 14, 2023 at 12:42 PM
    Emmylou26
    Emmylou26 [OP] New Member
    2009 Black Tundra
    Hi!
    I have a 2009 Toyota Tundra and recently I’ve been unable to unlock/lock the doors (from inside) with the power button without the power on. It helps when I take the keys out while my husband puts in gas and lock it with the power button, but I have to manually lock and unlock them all. It’s quite annoying and would like to know if anyone has had that problem and knows how to fix it. I can do it myself and would like to avoid taking it somewhere to have someone else fix it.
    Thank you!
  2. Apr 14, 2023 at 2:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Emmylou26[OP] likes this.
  3. Apr 14, 2023 at 2:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check to see if you fall under the TSB if you do make an appointment at your local dealer and take the TSB with you.
  4. Apr 26, 2023 at 5:29 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
