Help needed with Sway bar
Discussion in 'General Tundra Discussion' started by Seanson, Jul 8, 2016.
  1. Jul 8, 2016 at 6:56 AM
    Seanson
    Seanson [OP] New Member
    2010 Tundra TRD Reg Cab Short Box
    So after some long searches I've decided to make my own sway bar end links and installation hardware kit for my Trd sway bar. The best price ive found for both kits was 220$+ tax. Im kinda cheap and love to make my own parts.
    I know the links are 14'' centre to centre and I've already got the poly bushings.
    The only other info I'm missing is:
    -the length of the bolts and spacers
    - the dimensions for the u bolts and saddle brackets.
    Can anyone help me out ? If this works out I'll post a diy thread.
  2. Jul 8, 2016 at 3:42 PM
    RowdyRon
    RowdyRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I'm taking this information straight from the installation information that came with my rear sway bar:
    Upper End Link Bolts = M14 x 1.5 x 120
    Upper End Link Frame Spacers = no specs given but I measured mine and they look to be 1" long
    U Bolts and Brackets = not specified on the installation sheet
    Hope this helps some....
    Just remembered that someone else on the forum went through this recently. You may want to do a search for rear sway bar and see what comes up.
    GNTundra, Seanson [OP] and 15whtrd like this.
  3. Jul 9, 2016 at 5:11 PM
    Seanson
    Thanks !!
    Im assuming the bolts that go between the end link and sway bar are M14x1.5 as well??
    That kinda suck for me because the poly bushings I picked up for a M10 bolt. Ugh I'll have to find new ones... or just open up the poly bushings for a M14 bolt
  4. Jul 9, 2016 at 5:28 PM
    RowdyRon
    Ron
    Bentonville, AR
    The Lower End Link Bolts are M12 X 1.5 X 70
  5. Nov 1, 2016 at 3:20 PM
    knumb
    knumb New Member
    I measured my Upper End Link Frame Spacers and they were 1 1/2". I lost one and am trying to get a replacement but cannot find them anywhere including Lowes and Home Depot. Any ideas?
  6. Nov 1, 2016 at 4:27 PM
    RowdyRon
    Ron
    Bentonville, AR
    I would probably get a brass pipe nipple (Ebay has them) similar to this one of the proper diameter:
    Get one long enough and then cut the threaded portion off.
    knumb likes this.
  7. Nov 1, 2016 at 4:33 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Go onto McMaster Carr. They carry everything. Sorry I don't have the link.....
    knumb likes this.
  8. Nov 1, 2016 at 5:55 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Lowes sells the 1.5" spacers,you need two of them. They are in the specialty bins...
    knumb likes this.
  9. Nov 2, 2016 at 4:04 AM
    RowdyRon
    Ron
    Bentonville, AR
    Good eye, John! Found the spacers on Lowes web site for $1.15
  10. Nov 2, 2016 at 6:10 AM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2016 Tundra Platinum Edition, SIlver Sky Metallic
    I see others have provided some information. Attached is a copy of the Toyota instructions - it might help with perspective...
  11. Nov 2, 2016 at 4:14 PM
    knumb
    knumb New Member
    Thanks bud!
