10 amp TAIL fuse keeps blowing when I turn on the lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by SgtSausage1978, Sep 20, 2020.
  1. Sep 20, 2020 at 9:14 AM
    SgtSausage1978
    SgtSausage1978 [OP] New Member
    Utah
    2023 SR5 crew cab
    Hola... 2018 Sr5 5.7
    the 10 amp fuse under the steering wheel marked TAIL keeps blowing out every time i switch on the lights.. my running lights are out.. blinker, head lights, brake lights, license plate,dashboard, everything else seems to be working just the tail running lights are not on... I checked the bulbs they look fine,, swapped out the relay for one that works and it still blew a fuse.. i thought it was from when i hooked my boat up a few days back but now im not sure as it still keeps blowing without the trailer hooked up... Ive checked all the fuses in both boxes that sound related to towing or lights and they all seem fine... Whos a genius here????
  2. Sep 20, 2020 at 9:20 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    unhook the harness from the rear bumper and try turning on your lights. You may have a loose / exposed ground somewhere which will trigger a fuse to blow.
  3. Sep 20, 2020 at 10:18 AM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    fist off thanks for the help.. i tried unhooking the harness going to trailer light plug and then put in a new fuse, turned on lights and it blew.. is that the harness or is there another harness you’re referring too??
  4. Sep 20, 2020 at 10:24 AM
    blackdemon_tt
    Yes, that one, then I would revert to an exposed ground somewhere in the harness, which may require some digging. You can also check the grounds out of the fuse box which are located just behind the driver side head light, mine came loose for whatever reason and would blow out my head lights... Also check the grounding points under the kick panel and ensure those ground are tight and dry.
    Long ago, my car's fog lights had an exposed ground wire and it would blow out the fuse every evening when the lights popped on, or when I turned the light switch...
  5. Sep 20, 2020 at 10:37 AM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    phew never easy.. thanks again for the advice i’ll start digging .. good karma for ya
  6. Sep 20, 2020 at 10:55 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Mine did the same thing when i installed my NSV headlight patch harness .... but just fixed mine 2 hrs ago ... hope she holds up.
  7. Sep 22, 2020 at 4:40 AM
    couchpotato013
    couchpotato013 New Member
    If you can't figure out where the short is coming from, consider switching to a circuit breaker instead of a fuse. They make little circuit breakers that can fit into where the fuse goes, and they automatically reset. You'll want a Type I breaker for this. They'll be a lot longer than a regular fuse, but should still fit. The circuit breakers I used was just short enough to put inside the passenger side kick panel with the panel door closed on my Honda Odyssey. Bad usb/power cables kept blowing fuses on the 12v outlets.
    Example: https://www.littelfuse.com/products...uit-breakers/30418-mini-circuit-breakers.aspx
    Type I, II, and III explanation: http://info.waytekwire.com/blog/a-basic-guide-to-circuit-breaker-types
    You can buy unbranded ones on Amazon such as "T Tocas DC 14V 5PCS Auto-Reset ATM Mini Blade-Style Circuit Breaker (10A)"
    Still won't fix your issue, but if your tail lights are only intermittent it would help.
  8. Sep 22, 2020 at 4:58 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Its a cool idea but unfortunately if your truck has a DEAD SHORT even if you put a 200 amp breaker on it .. its just a band aid .. it will still pop .... need to trace and back track whatever you tapped to the parking light and simply put it back to factory set up.
    rockmup likes this.
  9. Sep 22, 2020 at 5:32 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Mine started doing this the other day, we're on the road for another week so I'll look at it when I get home. Not driving at night any time soon. The only change I made to it was the installation of Winjet tail lights before we left.
    Changed the fuse with a 15a because its all I had, popped right away, should be easy to figure out when I get time.
  10. Sep 22, 2020 at 5:55 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Good luck, might be those resistors pack that comes with the taillight.
  11. Sep 22, 2020 at 6:16 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Warranty? It's a 2018 so depending on mileage you might not have to deal with this and let a tech get frustrated instead
    landphil likes this.
  12. Sep 22, 2020 at 3:45 PM
    rockmup
    rockmup New Member
    Todd
    Not with a 15a fuse. lol
  13. Sep 22, 2020 at 4:04 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    Replacing a 10 amp fuse with a 15 can lead to a catastrophe. It probably won’t start a fire but it is possible. More likely it will damage a wiring harness that will have to be replaced. That’s not a cheap job. They put a 10 amp fuse in that circuit for a reason.
    Beesta likes this.
  14. Sep 22, 2020 at 4:29 PM
    Rubberdown
    So... is everything on your truck stock? I ask because people have these problems, then later they mention they wired in a lightbar, switched to aftermarket led bulbs, etc etc. might help us help you.
    good luck!
    ryan
    Beesta likes this.
  15. Sep 22, 2020 at 7:54 PM
    rockmup
    rockmup New Member
    Todd
    We just look at things differently, my experience tells me its not a big deal though I appreciate the heads up.
    I've built wiring harness's from scratch for several vehicles so I have a solid understanding of whats going on and the risks involved.
  16. Sep 22, 2020 at 8:11 PM
    tttrdpro
    SWGA
    In progress…
    Fair enough. You do you. My concern was there are probably a lot of folks on this board who have no education, training, or experience on electrical theory/issues. The way you stated things in your post could lead some of them to end up putting a 30 amp fuse where it should be 10. I have witnessed catastrophic results from similar actions. Just trying to keep someone from making a terrible mistake. I meant no offense.
    Beesta likes this.
  17. Sep 23, 2020 at 6:20 AM
    rockmup
    rockmup New Member
    Todd
    To be clear, I didn't say anything about a 30a fuse in place of a 10a. At 10a its a circuit that sees 6-7a max, nothing catastrophic is going to happen by putting a 15a fuse in that circuit, in my experience.
    Although it is 2020 so who knows. No offense taken at all, we should be able to have a civil discussion even when we disagree.
    Beesta likes this.
  18. Sep 23, 2020 at 6:33 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    A shorted ground will not blow a fuse, that’s what grounds do. If a ground in that circuit was shorted to the positive wire yes. A loose ground normally dim light. Never use a higher amp fuse. If no aftermarket lights I would take to dealer if you still are in warranty.
    Beesta likes this.
