Help! Axel Thread Pitch?
Discussion in '2.5 Gen Tundras (2014-2021)' started by dcsheppard, May 18, 2018.
  1. May 18, 2018 at 2:59 PM
    dcsheppard
    dcsheppard [OP] New Member
    clayton
    Austin, TX
    2014 CM SR5 4x4
    I boogered up the axel threads pulling my wheel bearing hubs. Does anybody know what the pitch os the spindle is? I’m hoping I can get a rethreading tool on it and not have to replace the half axel.
  2. May 18, 2018 at 3:01 PM
    koditten
    Kirk
    Midland of the Mitten
    I'd just file off the 1st few threads if you don't want pony up for a new axle.
  3. May 21, 2018 at 8:13 PM
    dcsheppard
    clayton
    Austin, TX
    2014 CM SR5 4x4
    Well, it’s not pretty....but that’s exactly what I did. They are 39mm 1.5 pitch, but a die for that is a bitch to find!
    Black@Blue19 and 15whtrd like this.
  4. May 21, 2018 at 8:41 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    @dcsheppard what'd you use to pull the hub off the axle? I removed the 4 bolts holding the dust cover/hub to the spindle, but can't for the life of me get the hub to move more than 1/8"
  5. May 22, 2018 at 2:53 AM
    koditten
    Kirk
    I had to use some flooring chisels to separate the hub bearing assembly from the spindle. Once I got the 1/8" mark I used some big chisels to get it to completely separate.
    I did give the axle shaft a pretty good smacking. I used a block of wood to protect the threads. I think the splines in the the hub bind up when pulling the hub assembly.
  6. May 22, 2018 at 4:00 AM
    dcsheppard
    clayton
    Austin, TX
    2014 CM SR5 4x4
    Man, I beat on it with a small sledge, pried on it with a chisel...and then Used a 6” puller and came off like butter. Definitely recommend the puller. I’m doing the other side tonight and will post pics.
    Black Wolf likes this.
  7. May 22, 2018 at 4:36 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I would be interested to see lots of pics. I've never had my axle apart, but I'm super curious. I almost want to just take mine apart just to see how it goes LOL
  8. May 22, 2018 at 4:56 AM
    dcsheppard
    clayton
    Austin, TX
    2014 CM SR5 4x4
    I used a 6” 3 jaw puller like this and once loose, it came right off.2A1F18F6-6551-4FC2-9471-EDB0AC2A2829.jpg
    osidepunker likes this.
  9. May 22, 2018 at 5:11 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Will a 7 ton (9") work?
  10. May 22, 2018 at 8:07 AM
    koditten
    Kirk
    That puller won't work. The center will just push on the axle stub. You need something that separates the hub from the spindle. I'm trying to figure how you made it work.
  11. May 22, 2018 at 11:50 AM
    dcsheppard
    clayton
    Austin, TX
    2014 CM SR5 4x4
    I loosened the hub first, to the 1/8" point or so, and then used the puller. Worked great. I'll get some pics and maybe video tonight when I do the other side. I hope this fixes the noise I've been hearing...replacing the drivers side did not.
  12. May 23, 2018 at 7:00 AM
    dcsheppard
    clayton
    Austin, TX
    2014 CM SR5 4x4
  13. May 23, 2018 at 7:16 AM
    koditten
    Kirk
    Yep, your puller did exactly what my block of wood against the axle stub did.
    You didn't really use the puller to remove the bearing assembly. Once the axle stub splines were free of resistance, the bearing assembly fell out.
    dcsheppard[OP] likes this.
  14. May 23, 2018 at 8:25 PM
    Help New Member
    Ryan
    Tucson, AZ
    I rented the same puller from Autozone, gonna give it a whirl this weekend when I have time.
  15. Dec 3, 2022 at 2:34 PM
    Bber08527116
    Bber08527116 New Member
    08 tundra
    I had done the same thing messed up the threads on cv shaft what's the best way to get the nut back on a die or file down the threads
