Hello everyone,
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lampis1, Sep 20, 2019.
  1. Sep 20, 2019 at 7:36 AM
    Lampis1
    Lampis1 [OP] New Member
    2017 Tundra 4X4 Crewmax
    N/A
    Taking my 2017 Tundra into dealership this morning to have the tech look at why both my roof moldings are now missing.. Would this be a defective clip that holds the molding to the roof?
    I called Toyota customer Service and they said I had to take it in for a tech to look at.
    27,000 miles.. any help here?
    Thanks,
    OR18TRD likes this.
  2. Sep 20, 2019 at 7:36 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome!
  3. Sep 20, 2019 at 7:37 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    That sounds odd. Whereabouts are you located?
  4. Sep 20, 2019 at 7:40 AM
    Lampis1
    N/A
    Santa Clarita,CA.
  5. Sep 20, 2019 at 7:41 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    You only noticed the moldings being gone recently? How long have you had the truck?
  6. Sep 20, 2019 at 8:46 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    One of mine came off on my previous Tundra. Found it in the bed of the truck. I could tell the clips were broken. Toyota replaces it under warranty.
    OR18TRD likes this.
  7. Sep 20, 2019 at 9:43 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  8. Sep 20, 2019 at 9:44 AM
    Lampis1
    N/A
    THank you !
    Truck is at dealership for tech to inspect.
  9. Sep 20, 2019 at 9:47 AM
    Lampis1
    N/A
    Purchased truck in June,2019 from Dealership, has 27952 on it now. Hoping warranty will cover both pieces. I have one of the molding clips still attached to the clip on the roof. I think it is defective part due to the adhesive is missing on the molding clip ?!!!
  10. Oct 16, 2019 at 3:47 PM
    P-Factor
    P-Factor New Member
    Yep, washed my 2018 today and both are missing with only 7,020 miles on the clock, and yes, I have washed it several times by hand previously and both were in place.
    I'd say Toyota has an issue with these clips staying in place.
    Part # 75561-RH and #75562-LH
  11. Oct 16, 2019 at 4:38 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I agree. The design is not good IMO.
    Oh, and hey there from Virginia!:mudding:
    P-Factor[QUOTED] likes this.
  12. Oct 17, 2019 at 11:09 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    TSB000115 replaces driver and passenger side drip molding on cab. I had this done on my 2015.
    https://www.tundras.com/threads/drip-molding.14202/
  13. Oct 17, 2019 at 11:28 AM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Welcome from NY.
    Do you use the car wash a lot? I've heard that's how they get loose and eventually come off.
