Heater Power and Dial
Discussion in '2nd Gen Builds (2007-2013)' started by Albinator, Nov 6, 2018.
  1. Nov 6, 2018 at 9:18 AM
    Albinator
    Albinator [OP] New Member
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    Hope this is in the right location.
    I have 3 questions about my heater/ac system.
    1) When it’s on the warm to hot marks and I push the button to recirculate (car symbol button in picture) and have it set for the air to push out to the floor and top (or any setting that’s not defrosting), after a minute or so it automatically turns off the circulation light. Why would it do this?
    2) for the dial where you set how want the air to be distributed, what do the settings mean with the dots that are in between the symbols?
    3) when I have the heater on, it blows the hardest/most heat on the 4th to last red mark. Any of the last 3 hot marks (turning in the hot direction) it doesn’t blow as hard. Why would that be?
  2. Nov 6, 2018 at 10:15 AM
    TTCrewmax
    TTCrewmax New Member
    1. Toyota built that into the HVAC - guess they were sick of people complaining that their windows were fogging up with the recirculate button on. It does this when the outside temp is less than 50 F. IIRC.
    2. Dots mean that it's favoring the label to the left - with a small mix of the label to the right. For example first logo - air is blowing through face vents - move it to the button between and majority of the air is coming through those vents with a small percentage going to feet. No idea what the % break-out is.
    3. Last question has me stumped. Not sure on that....
    NewImprovedRon likes this.
  3. Nov 6, 2018 at 12:13 PM
    Albinator
    Utah
    I really appreciate the detailed responses! Very good to know and now makes sense why that is.
    For question 3 (if you have the same-ish truck) maybe you can see if your truck does the same?
  4. Nov 6, 2018 at 1:34 PM
    15whtrd
    15whtrd Mr. Blonde
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    I had a truck awhile back that somehow short-circuited on the dial by being stuck in between two notches. I took it apart and found carbon buildup and melted plastic. It reminded me to make sure I always had the knob and a positive stopped position on each individual notch. If that makes sense. I cleaned up all the contacts and it worked flawlessly after that. Don’t know if the tender works the same but it might be worth looking at.
  5. Jan 27, 2019 at 5:32 PM
    dw8494
    dw8494 New Member
    Thanks for asking these questions. #1 & #2were answered and I personally thank TTCrewmax.
    For #3, I thought it was interesting you had this and had to confirm myself. That truly does happen, it's like @ the 4th last RED mark, it gets some extra power or something.
    Following to see if someone has an answer for us. Just stumped.
    Albinator [OP] likes this.
  6. Feb 1, 2019 at 9:53 PM
    Albinator
    Utah
    So strange...glad to hear it’s not just mine.
