Headlight blinker issue after Spyder install
Discussion in '2nd Gen Tundras (2007-2013)' started by Usmcassassin, Feb 15, 2019.
  1. Feb 15, 2019 at 4:52 PM
    Usmcassassin
    Usmcassassin [OP] New Member
    Ryan
    Colorado Springs
    2011 Tundra CM TRD Off Road
    6" Pro Comp, 35" Pro Comp Extreme MTs
    So I recently installed Spyder Drl headlights. Had to splice in to the DRL harness to get them to work. All worked fine until a day ago my driver blinker nor the DRL is working. And now the hyper fast blinker is happening.
    Also, one of my headlight high beams was bad so I got replacement ones today. I installed them just like before, now neither of them work and both blinkers are hyper flashing. Same install method. Bulb is good when I turn lights on. But no front blinkers on either side.
    Searched everywhere I can online with no definitive answer besides blinker fluid... Which obviously was the first place I checked.
    Any help is greatly appreciated.
    Ryan
  2. Feb 15, 2019 at 4:57 PM
    War Machine
    War Machine SSEM # 5 3MW
    If they are the same ones I had on my gen 2, I always had issues with them. Ended up putting stocks back on and tossing them.
