Head room.
Discussion in '3rd Gen Tundras (2022+)' started by Big B, Oct 19, 2021.
  1. Oct 19, 2021 at 9:31 AM
    Big B
    Big B [OP] New Member
    So far no one has mentioned if this truck has more head room than the old one. I'm 6'5" and feel like I have to duck to drive my current Tundra. The seat doesn't go down far enough.
    Anyone?
  2. Oct 19, 2021 at 9:33 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Do you have a sunroof? Way more headroom if you forgo that option. I will make an assumption this will still be an issue with the 3rd gen.
    https://www.tundras.com/threads/low-profile-seat-my-head-is-in-the-roof.92680/#post-2337861
    15whtrd likes this.
  3. Oct 19, 2021 at 9:34 AM
    Big B
    No I don't.
  4. Oct 20, 2021 at 1:49 PM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank)
    I’m 6’5 and have plenty of room. Maybe a 3 inch lift and move the steering wheel up with the seat tilted back.
  5. Oct 20, 2021 at 4:11 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    6'3 here with no issues... Step bars or those automatic step ramp thingy will help. Good luck
  6. Oct 20, 2021 at 5:14 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Long legs/short torso or short legs/long torso?? makes a huge diff
  7. Oct 20, 2021 at 5:17 PM
    nuttz565
    nuttz565 New Member
    Denver
    2020 DC SR5 LoooongBed Calvary Blue
    ToyTec Coilovers & Shackles Dirty Deeds 8” exhaust Method 18” Wheels Aftermarket tow mirrors
    First thing I noticed when I bought my 20 was how high the seating position was, felt like I was siting on top of the hood! I was coming from a 16 F-150 which had a much lower seating position. From what Ive seen I think the front head room is similar to the 21 but in the rear it looks to be less. There is a spec sheet floating around here that shows the actual dimensions of the 22.
  8. Oct 21, 2021 at 7:15 AM
    Article241
    Article241 New Member
    Patrick
    Prospective 3rd gen buyer
    The only interior dimension to increase is headroom in the front row. Slight gains in 2022 over 2021 for both DC and CM, with or without moon/panoramic roof.
    With the CM, a 1 inch gain in headroom with the panoramic roof over last gen's moonroof is welcomed, especially as it is standard on Platinum, 1794 and TRD Pro and optional on Limited.
    I really hope the next Sequoia will have similar headroom to the new Tundra as I don't fit in the current one.
    Headroom (front/rear)
    2021 DC 39.7/38.9
    2022 DC 41.0/38.5
    2021 CM 39.7/38.9
    2022 CM 41.0/38.5
    Headroom with moonroof (front/rear)
    2021 DC n/a
    2022 DC 39.3/36.9
    2021 CM 38.3/38.9
    2022 CM n/a
    Headroom with panoramic roof (front/rear)
    2021 DC n/a
    2022 DC n/a
    2021 CM n/a
    2022 CM 39.3/36.9
    Legroom (front/rear)
    2021 DC 42.5/34.7
    2022 DC 41.2/33.3
    2021 CM 42.5/42.3
    2022 CM 41.2/41.6
    Shoulder room (front/rear)
    2021 DC 65.7/65.6
    2022 DC 65.0/63.4
    2021 CM 65.7/65.5
    2022 CM 65.0/62.4
    Hip room (front/rear)
    2021 DC 62.6/62.6
    2022 DC 62.6/60.5
    2021 CM 62.6/60.4
    2022 CM 62.6/60.5
  9. Oct 21, 2021 at 7:23 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I know their price point is out of proportion to their apparent value; but I was researching seat comfort and found a lot of posts from taller folks touting seat jackers.
    FRONT SEAT JACKERS® (2007-2021 TUNDRA & 2008-2021 SEQUOIA) – Desert Does It
    If you're industrious and have tools you could make your own. I'm about 85% happy with the seats, and only 6' tall, so they're not high on the list; but they're on it.
  10. Oct 21, 2021 at 5:33 PM
    nuttz565
    nuttz565 New Member
    Denver
    I think the big issues from what I’ve seen is the rear head room, especially with the Pano at only 36.9”. Most reviewers have mentioned this as well. The gain in the front is welcomed for sure though.
  11. Oct 22, 2021 at 7:28 AM
    Breathing Borla
    also, how raked that A pillar is. now I have to bend down to get in my tundra since the A pillar is so raked.
    time will tell on the new 2022 if this is improved or not. the back seat with less headroom, legroom, etc will be tighter for sure
