Have a 3" leveling kit - Can I add a 3" lift Spindle and add a leaf to get ~6"
Discussion in 'Suspension' started by snektundra, Nov 18, 2020.
  1. Nov 18, 2020 at 9:13 AM
    snektundra
    snektundra [OP] New Member
    Ken
    2016 Tundra SR5 CrewMax
    20" Gear BigBlocks, 34" Falken AT's, 3/2 Level kit, PD Black Emblems
    I know this has probably been asked - so references to past threads appreciated.
    I have a 2016 Tundra 2WD CM that I put a 3" leveling kit on a few years back - but
    want to raise it to around 6" (2wd truck... all 4 looks).
    I am looking at adding a 3" lift spindle and longer shackles or an add a leaf in the rear
    to increase rear height on top of the 2" block I added with the leveling kit.
    I am running 20" x 9" wheels (Gear Big Blocks) with +18 offset so think I have clearance
    for the spindles.
    I see 6" spindle kits that use the strut spacer - so think my plan for the front will
    work. I am trying to keep the cost reasonable here without compromising safety
    and excessive wear on suspension.
    Is this plan a reasonable approach for a 2WD model - or totally a hack and I should
    go a different route. This site rocks - so would love any input from those who have
    been down this road. Thanks !
