Hate the rake...need help.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Torian13, Apr 23, 2021.
  1. Apr 23, 2021 at 8:33 AM
    Torian13
    Torian13 [OP] New Member
    2019 Tundra XSP
    2019 Tundra XSP
    Bilstein 5100 top setting and CB shims 2/1
    +3 shackles in rear
    Camburg UCA
    I realize the TSS is gonna give me hell, but I want my truck level with the +3 shackles in the back. My local dealership will allow me to sign a waiver that won’t cause warranty issues. What are my options for replacing the 5100s with that will get me to level all around?
  2. Apr 23, 2021 at 9:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    if you are at top setting and have shims, you are aleady about 3 inches lifted in the front. You should move to a rear shackle with less lift, likely 1 inch less than what you have will level the truck.
  3. Apr 23, 2021 at 9:23 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You’ve already maxed out your front
  4. Apr 23, 2021 at 9:27 AM
    Torian13
    2019 Tundra XSP
    I realize I have maxed out the front with the 5100s. I am asking about a different front suspension unit that would make the front level with the back with the +3 shackles installed
  5. Apr 23, 2021 at 9:28 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    3 inches is 3 inches regardless of suspension type. The front a arms pivot. You can only adjust the angle of them at ride height so much before ruining your ride/life of the components
  6. Apr 23, 2021 at 9:41 AM
    Torian13
    2019 Tundra XSP
    That makes sense. Thank you.
