Has anyone succeeded with anytime fog lights in 2021?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redline870, Oct 6, 2022.
  1. Oct 6, 2022 at 11:22 PM
    Redline870
    Redline870 [OP] New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Just as the title suggests, has anyone successfully completed an anytime fog light mod in the 2021. The topic seems to be ripe with fairy tales and hypotheses about which wires need to be cut and which wires need 12V ignition, etc, but I’ve seen no one who’s actually done it. Hopefully it’s a simple and straightforward process!
  2. Oct 7, 2022 at 1:44 AM
    I know you're asking about a '21 model, but I've done this to my '14 when I had it, there is a DIY MOD in Mods and Tutorials section on here
  3. Oct 7, 2022 at 3:58 AM
    pursuit2550
    pursuit2550 New Member
    Would be nice. I had it done on a previous tundra. Would like to have it in my 20 also.
  4. Oct 7, 2022 at 4:53 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I just turn on my parking lights. I don't believe much changes besides the taillights coming on with the fog lights being lit up.
  5. Oct 7, 2022 at 12:49 PM
    pursuit2550
    Fogs turn off when you put on your high beams.
    TXRailRoadBandit73 likes this.
  6. Oct 7, 2022 at 1:13 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ahh I thought the goal was to be able to run fogs only.
    Ignore me lol
  7. Oct 7, 2022 at 2:06 PM
    TTund16
    TTund16 New Member
    Unless you change the fog lights or the light bulbs, the factory fog lights are useless anyways!
    the fog lights are a joke in every car we have... You can see maybe 5 yards. Unless you are going 5mph and want to see 15 ft in front of you. They are like for decoration or Christmas lights.
    There was a document here I think it is called Eddie's fog light fix or something like that. Does it work for 2021?
    with Eddie's fix, you can have the fog lights on anytime as long as parking lights are on. You can turn the fog lights on with Low beam, high beam and parking lights only.
    There is another fix where you have to bend a relay pin ... Not sure which one is scarier or easier! lol
    I did the Eddy's fix (2016) and so far so good. I don't smell anything burning!
  8. Oct 8, 2022 at 3:45 PM
    Redline870
    Ian
    Central NY
    I have a Pro with the Rigid fogs. They’re not terrible for factory fogs. Though compared to the Rigid D-Series pro spotlights, it’s hard to believe they’re the same form factor. I’ve contemplated swapping out the OEM Rigid fogs with one of Rigid’s other D-Series Pro offerings.
    On the topic of the anytime fog lights, I’m hesitant if any of the alterations for 2019 and older would work on the 2021. They made some electrical changes to the lighting. For example, I can’t run LED turn signals because the modification for the flasher resistor doesn’t apply. The factory flashers are digitally controlled, not through analog circuitry.
    I’ll check into the mods you mentioned. Bending/removing a relay pin is easy enough to test out with some jumpers without having to permanently modify anything.
  9. Oct 8, 2022 at 4:19 PM
    Baja Designs likes this.
  10. Oct 8, 2022 at 6:07 PM
    TTund16
    TTund16 New Member
  11. Oct 8, 2022 at 6:54 PM
    Redline870
    Ian
    Central NY
    I don’t want them all the time, I want them on when my high beams are on since they light up more of the ditch…where the deer jump out from. Those that don’t understand that are not the sharpest tools in the shed.o_O
  12. Oct 8, 2022 at 6:57 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I did the write up on the relay mod. That’s your easiest way to get them on for the high beams
    TTund16 likes this.
  13. Oct 8, 2022 at 7:20 PM
    Redline870
    Ian
    Central NY
    Hey you came in with assumptions and started calling people dull tools!… agree with you though. The look of fog lights on with just parking lights is stupid. I’ve been seeing people do it for years and I’ve never understood it. Fog lights with the high beams is what I’m after.
    Sierradevil likes this.
  14. Oct 8, 2022 at 7:24 PM
    Redline870
    Ian
    Central NY
    After reading through that, a few said it won’t work on the 2020-2021. However, post 216 looks to have a solution. I’ve reached out to the poster for more info. Seems like it maintains all factory functionality while allowing the fog lights to operate while the high beams are on.
  15. Oct 8, 2022 at 7:26 PM
    Redline870
    Ian
    Central NY
    I was kind of cracking a joke and then agreeing with you to smooth things over, but clearly you’re just a douche. Unless you have something constructive to add, get lost.
  16. Oct 10, 2022 at 5:04 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I think people should be allowed to run fog lights whenever they want. They're not blinding to oncoming traffic or pedestrians and they don't both anything. Except peoples opinions.
    I could see fogs with high beams being beneficial. Even though they're short distance, they still illuminate the road and off to the sides.
    Redline870[OP] likes this.
  17. Oct 10, 2022 at 7:39 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Saltyhero13 likes this.
  18. Oct 10, 2022 at 11:37 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
  19. Oct 10, 2022 at 11:44 AM
    king.cong.1119
    king.cong.1119 New Member
    I know this maybe a far alternative, I just wired my fogs to my aftermarket control panel, so they can be independently turned on.
  20. Oct 10, 2022 at 11:49 AM
    Baja Designs
    Bill
    San Marcos, CA
    An aftermarket switch panel may be another option for the anytime fog lights. Baja Designs just recently acquired sPOD 4x4. They make aftermarket switch control panels that eliminate the mess of all aux lighting cords running everything to a can-bus system under the hood of your vehicle and one cord into your vehicle to a control module. I will insert the link below for anyone interested in this product.
    sPOD 4x4:https://www.4x4spod.com/
    Best,
    Brandon
    king.cong.1119 likes this.
  21. Oct 10, 2022 at 10:07 PM
    Redline870
    Ian
    Central NY
    That’s cool, I’ve never even heard of that. If that could keep me from doing some sort of rigged together setup, I think it would be $150 well spent. I’ll try to digging into it to see if I can find some more info on it. Thanks for sharing that!
  22. Oct 11, 2022 at 6:57 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    You're welcome. I found it awhile back and bookmarked it. I'm really interested to see if anyone has it and if they like it.
  23. Oct 11, 2022 at 11:42 PM
    Redline870
    Ian
    Central NY
    I actually have a switch pro 9100 but I didn’t want to cut apart the factory fog light wiring to make this work. It would be pretty easy to do though since the switch pro has the ability to turn outputs on and off via trigger wires and one of the trigger wires is already wired to the low beams to dim the control panel when they go on.
  24. Oct 13, 2022 at 12:34 AM
    Chris70
    Chris70 New Member
    coldcanuk likes this.
