Handor Coil Spring Compressor
Discussion in 'Product Reviews' started by Sumo91, Dec 15, 2021.
  1. Dec 15, 2021 at 5:24 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys, I know alot of us on here are the DIY type, and I recently got my hands on new coilovers that needed adjustment. So I bought a Handor spring compressor. I came across it on a Google search, and it seemed safer than the other cheaper options. After using it, I can say it's pretty heavy duty and I felt completely safe using it. Per the reviews I read, I greased the bolt before use to keep it from stripping or galling. It compressed both of my coilovers with ease. I used my impact, but used a ratchet as well out of curiosity, and it worked great too. If you need a spring compressor, consider this one. It's budget friendly, and you never know when you might need to adjust your coilovers.
    https://www.amazon.com/Handor-Spring-Compressor-Durable-Carrying/dp/B08MQPF6M3
    2mchfun likes this.
  2. Dec 15, 2021 at 6:09 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Cool review! I just use a spanner set, a piece of rope to hold one spanner, and a short cheater on the other. Slow and easy goin with some oil on the threads.
    Sumo91[OP] likes this.
  3. Dec 15, 2021 at 7:00 PM
    Sumo91
    TN
    If it works then keep on keepin on! I used a harbor freight seping compressor at first and thought I was going to die :eek:
    2mchfun[QUOTED] likes this.
