Handling issues 2015 platinum.
Discussion in 'Suspension' started by SmokedTundra, Mar 7, 2019.
  1. Mar 7, 2019 at 3:04 PM
    SmokedTundra
    SmokedTundra [OP] New Member
    Joe
    2015 Tundra crew max platinum
    Currently: Python alarm with autostart, JDMCar console organizer. About to do: Trd Sway bar, Amp Research bed extender, ESP under seat storage, DIY wireless phone charging mod, Tyger "star armor" running boards, Husky xact fit mats. Thinking about doing very soon and researching more: Lift or level kit (with closest to stock ride), replace the current 20" wheels with 18" trd pro wheels and BFGoodrich All-Terrain T/A KO2 Radial Tire -LT275/70R18/E 125/122R (or similar) Start of summer adding: Full stereo replacement with android auto/wifi head unit, midrange to high end speakers and amp, JL audio pre designed dual sub Tundra enclosure, Yakima 5 bike tilting hitch carrier with snowboard attachment, darkest privacy tint all around, LED headlights, possibly hard cover of some kind.
    Bought a 2015 platinum with 41k miles.
    Didnt notice the quirkiness of the handling/steering/alignment until having the truck a few days. Every bump I go over, any road imperfections, roadway ruts, will make the truck pull very hard to one side or the other. The truck pulls very hard to the right most of the time. It's like a workout to keep it straight and meanwhile I'm drifting in my lane trying to keep it straight.
    I had a 2008 tundra leading up to this that was easy to control on the road, wasnt scary to drive fast, didnt pull me all over the road. I'm pretty pissed off at this point, but that won't help so I'm just trying to fix it.
    The truck had autonation 125 point inspection, I've taken it to the local highly rated shop who did an inspection and said it was tight and didnt charge me anything.
    I just took it to Les Schwab and they did an alignment test and check it out and said everything looks tight and in spec and didnt charge me anything.
    Attached is the readout from the alignment test.
    What should my next step be?
  2. Mar 7, 2019 at 3:28 PM
    SmokedTundra
    Joe
  3. Mar 7, 2019 at 3:39 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Why don't you get a mechanic to drive it and give you his opinion?.
    SmokedTundra[OP] likes this.
  4. Mar 7, 2019 at 3:58 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^.
  5. Mar 7, 2019 at 4:14 PM
    SmokedTundra
    Joe
    Ty, was thinking this.
  6. Mar 7, 2019 at 4:15 PM
    SmokedTundra
    Joe
    If it is, it wasnt disclosed. Looks stock and I measured the height and it appears to be stock.
    Watt maker likes this.
  7. Mar 7, 2019 at 4:16 PM
    SmokedTundra
    Joe
    Les Schwab just set them at 30 psi
  8. Mar 7, 2019 at 6:08 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    too low!
    I have the newer version of that tire, same size, same truck. I run at 36 psi front 34 psi rear.
    Here are the alignment numbers I use, taken from another forum *not my work* .
    "In the green" isn't good enough. I tell them to match these numbers. I've run this on two trucks, one lifted, one upgraded suspension, and won't go back to "in the green" numbers.
    STOCK TRUCKS:
    Camber: +.1 degree camber on both sides.
    Caster: As much as possible without sacrificing +.1 degree camber or causing a cross caster pull.
    Toe: +.12 degrees per side for a total toe of +.24 degrees. (some guys have had to drop toe to +.04 to +.5 per side/+.08 to +.10 total toe)
  9. Mar 7, 2019 at 6:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Agree. Air pressure is too low.
  10. Mar 8, 2019 at 10:57 AM
    SmokedTundra
    Joe
    Ty! I will try this!
    AxelsHumanDad[QUOTED] likes this.
  11. Mar 8, 2019 at 10:58 AM
    SmokedTundra
    Joe
    Could this issue be the tie rod ends?
  12. Mar 8, 2019 at 11:13 AM
    Walleye
    Walleye New Member
    Could be a tie rod end, but I'd expect a mechanical inspection to reveal this or excessive ball joint play readily. I also assume you don't have a brake pad hanging up or problems with abs wheel speed sensor. I also agree tire pressure is too low. A broken belt in a tire can cause the symptoms, but the inspection didn't identify this. Have a mechanic drive the truck and ride with him / her.
  13. Mar 8, 2019 at 11:33 AM
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
  14. Mar 27, 2019 at 9:46 PM
    SmokedTundra
    Joe
    UPDATE:
    I took this into Toyota and had them do an alignment test. This is the printout and it seems fairly similar the the Les Schwab one from a few days earlier.
    I had a mechanic at Toyota ride with me and even though I could see it pulling on the guy and pointed it out to him he told me me that "it drives like a tundra". I didn't feel as though he was being 100% with me as I had bought the car there and it's under their 4 month 0 deductible warranty. He also would not align my truck to the specs that others in this thread have stated to ask for. He said it was a liability issue.
    I went to another Toyota dealership and found a nice salesman who I told my story to and they let me test drive a 2019 to see if it felt different or pulled.
    The 2019 drove straight as an arrow. No pulling sensation. The steering felt tighter. My steering wheel on my 2015 feels much more "loose" and continues to pull to either side, mainly the right depending on the road surface. The 2019 did not do this at all, felt like a normal truck tracking straight down the road. So I know it wasn't the wheels now... my tires have decent tread left, but they are the original tires that came with the truck, so they have 42000 miles on them. Maybe it's all the tires?
    I guess my next option is to take it to the friendly Toyota dealership and have them spend a couple billed hours diagnosing and hope they find something my warranty covers to fix?
    Thanks all!
  15. Mar 28, 2019 at 3:58 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    What size wheels was stock? Are the wheels aftermarket?
    I have the same problem with my new '18. Toyota has aligned to spec but it still has a pull. I haven't had time to do it but i'm going to a local shop and let him drive it to see how it is. I think toyota doesn't account for wheel size change when they plug in the numbers.
  16. Mar 28, 2019 at 5:47 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Wondering. If you bought it used (with 41K on it) then we really don't know for 100% sure that it hasn't had any sort of frame damage. Toyota allows so many millimeters out of perfect frame alignment and still be, technically, "within spec."
    In my 1997 T100 I hit a curb pretty good. It knocked the frame over. It measured 6mm out of perfect frame alignment. Toyota "allows" 5mm. I left it. With a perfect wheel alignment and some adjustment of the torsion bars it still has a slight pull to the right that I have to actively resist with the steering wheel.
    A decent body shop with a frame machine should be able to measure it, give you a printed report and provide comments for $100 - $150.
    I'm just spitballin' here.
  17. Mar 28, 2019 at 6:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Increased caster helps a vehicle track straight and the steering wheel return to center. I find that .5* more caster on the right helps compensate for road crown and your caster is higher on the left side.
    It's easy to jack up one front wheel at a time and try to move the wheel to check for bad tie rods and/or BJs. Maybe check the BJ at the spindle to UCA while there. Then the rack bushings kinda take 2 people to inspect. 1 person, with the truck on the ground, moves the steering wheel back and forth a little while the other person looks for movement of the rack.
