Gun Safe Location
Discussion in 'Guns & Hunting' started by JH5370, Jun 26, 2019.
  1. Jun 26, 2019 at 3:41 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Where do you all keep your gun safes? I am in the process of finalizing house plans and am looking for a good spot to put my safe. The vault room I had planned got vetoed so now I'm left with coming up with a new idea. I am going to have a climate controlled garage so that is an option but was hoping for something better than that.
  2. Jun 26, 2019 at 3:58 PM
    LML 3500HD
    Did you cancel the custom kitchen as well?
    A vault in the building stages is the optimum time for cost.
  3. Jun 26, 2019 at 4:13 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    The kitchen is mostly for me so that would be shooting myself in both feet. It did get the addition of a kegerator. :cheers:
    It just wouldn't work with our floor plan without adding on to the house. It's a single story so not as easy as converting an unused room in the basement.
  4. Jun 26, 2019 at 4:15 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Mine is relatively small so I tuck it into a closetor corner and bolt it to the studs. The tight quarters prevent prying tools from being used effectively. A cordless angle grinder would make fast work of it but that's impossible to protect against imho
    ColoradoTJ likes this.
  5. Jun 26, 2019 at 4:19 PM
    LML 3500HD
    That makes sense.
    Garages are not a good spot. Garage doors are easy entry points. If your safe isn’t bolted down without the possibility of putting a cable or tow strap around the safe and yanking on it with a 7800 lb truck.
    Corner of room, bolted to floor.
    TRD-tv, jewsNbrews and JH5370[OP] like this.
  6. Jun 26, 2019 at 4:20 PM
    JH5370
    JH5370 [OP] Member
    Josh
    Eastern WA
    That's the set up I have currently as our office is a bedroom but the new home office will not have a closet.
    Outbound[QUOTED] and jewsNbrews like this.
  7. Jun 26, 2019 at 4:51 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Mine is in my basement. We have a finished basement with a bathroom at one end and a small room next to it that was just extra storage. That little room is now my gun/hunting/fishing room. My safe just sits against the wall but I plan to frame it in when I get some time.
    porkitt and jewsNbrews like this.
  8. Jun 26, 2019 at 4:56 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I agree, closet or corner, bolted down. I have a basement I will be placing mine in. However, until a new safe is installed, all rifles are at my dads in his safe. Only hand guns at my place for now.
    porkitt and JH5370[OP] like this.
  9. Jun 26, 2019 at 5:07 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    closet in the master bedroom. Takes up about half the closet but I am single so its all good LOL
    jewsNbrews likes this.
  10. Jun 26, 2019 at 6:17 PM
    18TRDSport
    18TRDSport New Member
    Western Mass
    2018 TRD Sport Sequoia in White
    Window tint, terrainContact AT tires, skid plate, less restrictive muffler and TRD air cleaner
    The hard part about figuring out where to put your safe if you think like you do...a reasonable individual.
    You need to start looking at it through the optics of a criminal. You cannot stop someone from taking your stuff when you are home or not. You can make it difficult. For instance, a safe in a garage. How long would it take someone to put a chain around the safe and pull it down the street? Now how about punching a hole in the wall and driving it down the street. Your 1000# safe will easily go onto a dolly and be carted away easily.
    My suggestion, put it somewhere where it cannot be seen by someone from the street or someone you hire to do work for you in the house....energy consultants and the like.
    porkitt, JH5370[OP] and jewsNbrews like this.
  11. Jun 28, 2019 at 9:50 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    I got a big ole Cannon safe that weighs a ton bolted to the floor tucked in a corner in my garage it was too big to get down my hallway to the bedroom.
    P-Factor and NewImprovedRon like this.
  12. Jun 28, 2019 at 10:41 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Block off a closet and buy a door for it.
    If you have an office in your plans that is where I would do it.
    Double dry wall and cinder block the walls.
    Add the door
    Mine has a book shelf in front of it
  13. Jun 28, 2019 at 11:16 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    If it’s a small quick access safe, were every you can get to it quickly. A large storage safe is best in the basement or first floor. A firefighter said to me they worry about heavy safes falling through the top floors on top of them when they are in a house fighting a fire.
    NewImprovedRon likes this.
  14. Jun 28, 2019 at 12:33 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Big safe is out in the garage along the exterior wall, bolted to the floor. My firefighter neighbor told me this was the better option because the garages in most home fires are not as "hot" as the interior of the house- More fuel inside the house with furniture (and wifey clutter).
    Small but heavy ass safe upstairs in the "safe room" / wife's closet.
    Vaultek on my side of the bed.
    My son has a rifle safe under his bed bolted to his bed frame.
    ... too bad all my guns sank on that horrible boating disaster...
  15. Jun 28, 2019 at 12:44 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    You could always have a decoy safe. The easier it is to find the decoy the less time they'll have to spend on the rest of your house. Sleight of hand kind of thing.
  16. Jul 1, 2019 at 8:56 AM
    fusion94
    fusion94 Just some dude...
    Tony
    Half Moon Bay, California
    2015 Barcelona Red Tundra CM SR5 5.7L 4x4
    All my safes are bolted to the floor in my garage. I have separate safes for firearms and ammunition.
  17. Dec 28, 2019 at 5:57 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    My dad had a large wall safe in his workshop/office in the back yard. Kept small amount of cash and lots of rolled up change in it, with the door "accidentally" left unlocked. Figured if someone broke into the workshop and seen the safe, would take the quick easy cash and not continue and find his hidden, reinforced safe with all the long guns and important stuff.
    aperezsh likes this.
  18. Jan 24, 2020 at 2:06 PM
    Smily
    Smily New Member
    2004 tundra v6 pain in arse suicide door
    Someone put a crappy stereo in it
    Hello all !
    I will add an interesting thing you can do to ur safe to ensure you get back what you stuck in there in case of a fire. Living in California for the last quarter century and every year watching the Northern fires get worse, people think a fire rated safe is the way to go, then find out it failed because the fire raged so long the safe heated like an oven destroying the contents. When I get around to building my safe into the wall I plan to use 1 or 2 layers of CORE BOARD the type of fire resistant sheetrock that's over an 1 inch thick and is used in fire rated restuarant equipment shafts. Then if you have an out of control blaze you wont have to worry as much about the heat. Somthing to think about for all yer safes not just the weapons.
    Good luck
    equin, JH5370[OP] and NewImprovedRon like this.
