Grinding from rear around turns after 3.5" lift
Discussion in 'Suspension' started by PNWtundrite, Oct 17, 2024.
  1. Oct 17, 2024 at 12:09 AM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Lifted my truck with below hardware at the recommendation of extreme terrain. Wonder if I was not supposed to use the blocks and rear sus together. Now I hear grinding on left or right low high G turns from rear. Thinking axle angle changed to much. And questioning if front diff drop is actually the answer or .....
    Installed Hardware:
    Front
    • Bilstein B8 5100 Series Front Shock .87-2.30-Inch Lift
    • Eibach 2inch lift springs
    • Freedom Offroad Front Upper Control Arms for 2 to 4-Inch Lift
    Rear
    • Bilstein B8 5100 Series Rear Shock for 2-Inch Lift
    • Supreme Suspensions 2-Inch Pro Billet Rear Lift Blocks
  2. Oct 17, 2024 at 8:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Usually when rear is lifted on a leaf spring tundra a carrier bearing drop is needed. I needed one when I raised my rear just 1 inch.
    Id start there, carrier bearing drop and see how it responds.
  3. Oct 17, 2024 at 4:36 PM
    Dgravee
    Dgravee New Member
    2010 tundra sr5 crewmax
    Probably not it because you didn’t mention any other work, but when I did my coilovers, I replaced the tie rod ends. Like a dummy I put the left on right and right on left - this caused it to rub the inside of my rims when turning.
