Grill lights
Discussion in 'Lighting' started by Njmike13, May 10, 2017.
  1. May 10, 2017 at 10:43 AM
    Njmike13
    Njmike13 [OP] New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Hi all,
    Just got my 2017 double cab SR5 / TRD in blazing blue pearl. I would like to change the grill to a TRD PRO to cut down on the amount of chrome on the front. I also need to add lighting to the front of my truck. Can anyone recommend lights or mounting options? I had rigid industries 10" light on the front of my old truck and loved it. Looking for both distance and wide angle lighting. Those Amish buggies on the road are a real problem at night.
    Thanks
  2. May 10, 2017 at 11:26 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    NewImprovedRon likes this.
  3. May 10, 2017 at 2:13 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mike, welcome to the forum from Las Vegas!! I have a 22" on the front grille guard and a 50" on the roof. I doubt you will want a grille guard like mine so it may not matter anyway.?.?.?.?
    Maybe something like this???
  4. May 10, 2017 at 4:58 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    LED spots in the middle and floods on the ends...
    Puud and NewImprovedRon like this.
  5. May 10, 2017 at 6:36 PM
    42" then i added single row just above license plate from rough country 32"
  6. May 10, 2017 at 6:48 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome to the forum Mike. With a TRD pro grill you can mount a 40" bar on the lower portion of your grill. You can also install a 30" single row or double row lightbar in the bumper. Pending what you want. You can also install the 40" NSV auto upper hood bulge led. Or you can do all three like I did. IMG_6715.jpg
  7. May 10, 2017 at 6:50 PM
    1UPPER!!! lets see night shot all lights on from inside cab w highs n lows ;)
  8. May 10, 2017 at 6:54 PM
    1UPPER
    TEXAS
    Flux capacitor!
    This is the last time I had all my lights on before I installed the 30" in the bumper. IMG_6070.jpg
  9. May 10, 2017 at 6:56 PM
    Aye cabron!!! Zombie hunting!!! Awesome!!! Me likey might take off my single row above license plate for a double place single in the bulge slot
  10. May 10, 2017 at 7:04 PM
    Njmike13
    2021 PRO Lunar Rock
    Looks sweet! Did you trim the grill mesh to install the 40" bar on the lower part of the grill? I like that it's flush and it's easy to clean the lens. That would be ideal for me. What brand light is that?
    Thanks to everyone else for the pics and ideas also.
    1UPPER[QUOTED] likes this.
  11. May 10, 2017 at 7:27 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Yes I did cut the lower plastic mesh to fit the light bar. I also trimmed the left and right side of the TRD pro grill to make the light bar sit farther forward. I also used washer on my light bar mount to raise the light bar to the same height as the grill opening. That is a 40" Rigid Radiance light bar in the grill. You can use another brand or style if you want. Other members have installed their light bars behind the stock mesh instead of cutting the grill.
  12. May 10, 2017 at 7:28 PM
    1UPPER
    TEXAS
    Flux capacitor!
  13. May 10, 2017 at 7:32 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Side profile pic showing the mount. I did have to notch my brackets to allow the grill to fasten into the stock clip points. IMG_4929.jpg
    It's also important to brace the center of the light bar to the center radiator brace. This will keep the light bar from moving.
    SlickRick2013Tundra likes this.
  14. May 10, 2017 at 9:34 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Did the bar cone with mounting brackets or were they a seperate purchase?
  15. May 11, 2017 at 4:04 AM
    Njmike13
    2021 PRO Lunar Rock
    Good info 1 upper, thanks. Steve I live just above Clinton off RT31.
    SouthBoundSteve likes this.
  16. May 11, 2017 at 4:20 AM
    1UPPER
    TEXAS
    Flux capacitor!
    The side brackets came with the light. The center bracket I made out of aluminum angle. Also the center bracket is what allowed me to set my lights projection. I kept adjusting the center bracket until I had the light where I wanted it.
  17. May 11, 2017 at 8:04 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Rago Fabrication just released a 42" lightbar and bracket for the upper hood bulge for $249! It's 12,000 lumens which is a lot of light. IMG_7535.jpg
  18. May 12, 2017 at 4:58 AM
    Njmike13
    2021 PRO Lunar Rock
    I like it! Any opinions on rago lights? I have only used rigid industries in the past.
  19. May 12, 2017 at 5:48 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Whittling??
    I'm picturing you out there with Swiss Army knife
  20. May 12, 2017 at 5:53 AM
    1UPPER
    TEXAS
    Flux capacitor!
    My experience is great with Rago Fabrication brackets but I don't know on the lights themselves. I run Rigid for my light but there a lot more money for sure. What I've noticed on some of the cheaper lights is they can have a less focused light beam and the lenses can turn yellow from sun fade over time. I'm not sure how Rago lights will hold up over time but I know the owner is a stand up guy. I would suggest calling him and see if he has a warranty for the lights.
  21. May 12, 2017 at 6:10 AM
    gosolo
    Ray
    NW Oregon
    More like dremel carving. Watching the install video makes it look pretty primitive. Then there's the comprehensive wiring instructions,"wire it up". I guess there's a reason it's cheap.
  22. May 12, 2017 at 6:16 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I was wondering the same thing about the wiring. I don't know if they have anything for the wiring included.
  23. May 17, 2017 at 8:01 AM
    Njmike13
    2021 PRO Lunar Rock
    Can anyone tell me what light mount this is?542b6938-60b4-4c3d-912f-7f4aa575d436_zpsjzq34ary.jpg
