Grill Advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by osucowboy96, Dec 28, 2018.
  1. Dec 28, 2018 at 3:44 PM
    osucowboy96
    osucowboy96 [OP] New Member
    Wichita Falls, TX
    2017 Inferno CrewMax
    I bought a grill on eBay with the 3 amber LEDs (listed for $132, offered $100, they countered with $98 :notsure:, go figure). I'm trying to decide if I want them on all the time, or just when the parking/head lights are on. Since the truck already had the orange daylight running lights on all the time, I think the grill LEDs would look good on all the time as well, but not completely sold on it. I need some advice!
    Also, currently they are wired into the side amber parking lights, where could I easily wire them for always on when the key is on?
    TokerJoker likes this.
  2. Dec 28, 2018 at 3:58 PM
    Mnorris1206
    08 tundra
    On all the time. O and looks really nice !
  3. Dec 28, 2018 at 4:41 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Under the hood, in the fuse box, there's a fuse you can use and use a fuse tap, it'll be on when you turn your key on. Got a Ebay link? I need a new one. I tapped mine under the dash fuse box to parking lights.
  4. Dec 28, 2018 at 4:52 PM
    osucowboy96
    Wichita Falls, TX
    HERE
    Thanks for the advice on where to hook up. It's a dark grey, not black, and comes complete with the surround. I didn't like how the dark grey butted up to the black bumper, so I removed the insert and kept the chrome surround.
    Berdine[QUOTED] likes this.
  5. Dec 28, 2018 at 5:45 PM
    Berdine
    Binghamton, NY
    That's the one I have on my watch list already. Haha
  6. Dec 28, 2018 at 5:46 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome new member
    osucowboy96[OP] likes this.
  7. Dec 28, 2018 at 8:34 PM
    natethenewbie
    natethenewbie New Member
    Oakland, CA
    2015 Tundra CM 4x4
    ADD Bumper, TRD Pro Exhaust, Icon Suspension, Method 17's wrapped with BFG A/T 35's
    After I crunched my oem grill on a deer, I got this grill and hooked it up exactly as Berdine says. Painted it and the surround to match. Happy with it.
    TokerJoker and Berdine like this.
  8. Dec 28, 2018 at 9:05 PM
    osucowboy96
    Wichita Falls, TX
    Are fuse taps safe? From what I've read, they could be a fire hazard. I don't want to take any chances, especially if it'll void my warranty.
  9. Dec 28, 2018 at 9:16 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Can anyone post a pic of there fuse tap and which fuse they used! Thank you!
  10. Dec 28, 2018 at 9:21 PM
    natethenewbie
    Oakland, CA
    2015 Tundra CM 4x4
    Never heard of a problem with an Add-a-fuse kit. They are, errrr, fused, so you’d have to go out of your way to create a fire hazard. Besides, we’re talking about very low current. I can’t imagine a problem or warranty issue.
  11. Dec 28, 2018 at 9:23 PM
    natethenewbie
    Oakland, CA
    2015 Tundra CM 4x4
    I’ll take a picture tomorrow. Any fuse that is keyed off ignition will work though. Just poke around with multimeter. Hardest part is running wire through the loom into the box.
  12. Dec 28, 2018 at 9:24 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Appreciate it thank you!
  13. Dec 28, 2018 at 9:43 PM
    osucowboy96
    Wichita Falls, TX
    What I read was that adding current to a fuse rated for what's it's there for could cause issues, and if you put in a bigger fuse it could cause the existing wiring to overheat since it's likely not rated for as high as the new fuse. I figured since the lights are LED that the added current would be negligible, but just want to be sure. Thanks for all the info.
  14. Dec 29, 2018 at 4:56 AM
    Berdine
    Binghamton, NY
  15. Dec 29, 2018 at 10:10 AM
    osucowboy96
    Wichita Falls, TX
    Awesome, thanks! Does this fit well without modifications to the box? i.e. does the adapter sit too high for the box to close properly? And this is probably a dumb question, but where is the fuse box located that this will plug into?
  16. Dec 29, 2018 at 10:21 AM
    Berdine
    Binghamton, NY
    Under the hood, the box will close fine, you'll have to cut away some to route it out. Under the dash, you can't put the cover back on, which is fine it's under the dash away from the elements.
  17. Dec 29, 2018 at 10:21 AM
    Berdine
    Binghamton, NY
    You can pick those up at your local auto store too
  18. Dec 29, 2018 at 10:34 AM
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    Guys what do you think of my new hood
  19. Dec 29, 2018 at 11:21 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    That is so nice!
    mohd.darmaki[QUOTED] likes this.
  20. Dec 29, 2018 at 11:45 AM
    natethenewbie
    Oakland, CA
    2015 Tundra CM 4x4
    Here ya go. Grab an add-a-fuse kit. Find a keyed ignition source. You can see by my finger where i found one. Run the wire through the loom on the left (the plastic elbow comes out and apart). There's plenty of headroom in the box.
    sEW2RYg30d8a3lo68S_pSBh5Paj9zcfJJ3-Ea2an_9ea68c9a641ea9479d67b09943b43e78088141e0.jpg
  21. Dec 29, 2018 at 2:32 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    Mohammed, that truck in my opinion is... BADASS!!! :thumbsup: More pics please.
  22. Dec 29, 2018 at 2:57 PM
    osucowboy96
    Wichita Falls, TX
    Awesome, thanks!
  23. Dec 30, 2018 at 6:23 AM
    mohd.darmaki
    Mohammed
    Thanks 9F5ED724-817C-45D8-9AB5-1B6977ADE14E.jpg2CDAF1E2-3805-4383-9D44-A05EF26F6443.jpg 04F4E042-FFF5-463E-8636-9CDDA36E615C.jpg
  24. Jan 1, 2019 at 3:47 PM
    osucowboy96
    Wichita Falls, TX
    UPDATE: Purchased the recommended add-a-fuse and rewired the LEDs. Was kind of a pain, as I had a mechanic friend wire it to the parking lamp on the headlight originally. I had to remove the headlight to disconnect it (which required removing the grill and the small panel under the headlight). Was pretty worried taking everything off, but got it disconnected and everything reassembled.
    Ended up just drilling a hole into the fuse box, just big enough for the wire to fit through snugly, as I didn't want to mess with the existing wiring to try to feed it through an existing access. Only issue I have is the add-a-fuse doesn't fit real snug, so I'm concerned it may jostle out eventually.
    Thanks for all the help and advice, it's working just the way I want now, always on with key. Now to find a badge I like to affix to the grill, thinking I like the TForce emblem that's on my wheel center caps.
    Berdine, jewsNbrews and natethenewbie like this.
  25. Jan 1, 2019 at 4:07 PM
    natethenewbie
    Oakland, CA
    2015 Tundra CM 4x4
    Looks sharp - good job.
  26. Jan 4, 2019 at 9:51 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Quick question do you know what the fuse you tapped controls? I’m thinking about tapping the same fuse.
  27. Jan 4, 2019 at 11:32 AM
    osucowboy96
    Wichita Falls, TX
    Sorry, I have no idea. I just used that one based on the recommendation above.
  28. Jan 5, 2019 at 9:16 PM
    natethenewbie
    Oakland, CA
    2015 Tundra CM 4x4
    Just find one that’s switched to your ignition. Beyond that, it probably doesn’t matter. The electrons don’t care.
  29. Jan 5, 2019 at 9:21 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Thanks for the help everyone I ended up deciding to tap into the headlight fuse so it comes on with my headlights!
    natethenewbie likes this.
  30. Jan 17, 2019 at 4:25 PM
    osucowboy96
    Wichita Falls, TX
    Update for anyone that cares, and another question for you electrical experts. I decided the grill was too plain with no emblem, so I ordered a
    Toyota Land Cruiser 1985-1987 BJ70 Front Grille TOYOTA Emblem 75311-90K00 off of ebay for $35, then created and cut some chrome vinyl lettering to cover the white letters on it. They don't fit perfect, but I got tired of measuring and re-cutting, and from a distance you can't really notice. It actually fit pretty nice and centered up really well on the grill. I had to drill small holes into the pegs on the outside of it so I could mount it with 3 screws (sandwiched onto the grill using washers in the back).
    My question(s) for the electrical experts is this -- The mechanic friend that originally hooked up my led's ran the ground to the negative terminal on my battery. I've read elsewhere that things should be grounded to the frame. Does it need to be on the negative terminal of the battery? Is there risk of this? Would it be better to run it to a bolt on the frame?
    Thanks in advance, this forum is awesome and I've already learned a lot from just reading through threads.
    mav7021234 likes this.
