gremlins in the truck: switch pros, dead battery...
Discussion in '3rd Gen Tundras (2014+)' started by smslavin, Nov 16, 2018.
  1. Nov 16, 2018 at 9:14 AM
    smslavin
    smslavin [OP] On a plane...
    Denver, CO
    2016 Tundra CrewMax SR5
    Weather on the east coast was super crappy yesterday so I landed last night about 2.5 hrs late. Shuttle dropped me off at the parking garage, I walk up to the truck and it's clicking. An audible click coming from under the hood. Key fob not working. Dead battery. Unlock the door, look inside and the SwitchPros is blinking in time with the click from under the hood. Stick the key in the ignition just to double check and it's dead dead.
    Truck is backed into the space and up against the fence so I can't get in the back to get my battery jump. Had the brilliant jet lagged idea of putting the truck in neutral and squeezing myself between it and the fence to push it forward. That lasted about 3.74 seconds and I wandered off to find someone to give me a jump.
    Super nice guy came and helped. Truck started right away and all the light bars fired up at the same time. Everything turned off except for the 20" amber on the bumper. One of the shuttle drivers stopped and said, 'you know, your truck has been flashing all week. thought it was kinda weird.' Yea, thanks. I'm sure it was weird.
    So the switch for the amber bar wasn't working and the orange indicator light was not on. All other connected switches worked just fine. Pushing the switch for the amber bar caused the orange light to blink 4 times then stop. Poked around under the hood but couldn't see anything out of the ordinary. I was beyond tired and decided to just head home.
    People on the freeway at 11:30 at night are not a happy bunch. They were not amused with the nuclear yellow barreling down behind them.
    Off the freeway and almost home, I pull over and shut the truck off to see if I can reset things. Truck is off but the amber bar is still on. I give it a couple of minutes thinking the SwitchPros just needs to drain its charge for the bar to go off. Nope. Stays on. Turn the truck back on and the button is doing the same thing.
    I pull in the driveway and it still doesn't shut off so I crawl under the truck and unplug the connector for the bar. Light is off. Time to go to sleep.
    I was just outside taking another look at it. Truck is recharged and started just fine. Shut it off, plugged the light bar back in, turned it back on and the bar stays off. Pushed the button and it does the same thing. 4 orange blinks then nothing. All other switches are normal and lights operate as they should. I tried the app on my phone thinking it might override but no, the button in the app blinks for times too. The app also operates all other switches normally.
    I unplugged the main connector on the SwitchPros 'brain' to try and reset it. Didn't change anything. Switch doesn't work and the bar does not come on.
    Something went haywire somewhere but I know not where. Any ideas?
  2. Nov 17, 2018 at 5:53 PM
    smslavin
    Denver, CO
    831Tun, Grey Wolf, JDL17CM4x4 and 4 others like this.
  3. Nov 17, 2018 at 6:30 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Short inside the switchpro? Might be something you'll have to contact them about. They might replace it.
    smslavin [OP] likes this.
  4. Nov 17, 2018 at 6:38 PM
    Squatting Pigeon
    Squatting Pigeon Not so funny meow, is it?
    Holden
    Fort Worth TX.
    3rd Gen Black Crewmax
    @Larmand had an issue with his Switch Pros, IIRC it was switch #7 that wasn't working correctly.
    Turned out to be a bad connection somewhere in the sealed switching block and they warrantied it out for free.
    How long has your Switch Pros been installed?
  5. Nov 17, 2018 at 6:39 PM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    Could also be a trigger wire depending on how you wired it up obviously. Guessing you're running the 9100.
  6. Nov 17, 2018 at 6:47 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    BAMuffler 8" Catback, ADS 2.5 Coilovers, TC Heim Joint UCA's, TC Spindle Gussets, Wheelers Superbumps, CB Steering Kit, Carrier Bearing Drop & ABS Drop Kit, Rear ADS Triple Bypasses w/Deaver U748 Springs & TC Shackles, 17" Method Standards, 35/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Manufacturing Bumpers, RCI Skid Plates, White Knuckle Sliders, LED's Everywhere
    I had a weird situation with my Switch-Pros recently. Just the outside cells of my grille light bars were on but really dim. Everything else connected to Switch-Pros worked fine. I went through all the same checks you did to no avail. I started checking the connections and found the main ground wire loose inside the connector. Replaced the connector and haven’t had any more issues.
    It might not be your issue but a loose ground can make some weird electrical shit happen.
    MT Madman and Watt maker like this.
  7. Nov 17, 2018 at 7:00 PM
    Larmand
    Larmand Im 100% correct, part of the time! TTC #145
    Lucas
    Fort Worth, TX
    Yes, i did recently have an issue with my #7 switch. I called them they walked me through a few troubleshoooting steps. Proceeded to tell me that they never had this issue before. Asked me for a serial number and sent me a new one.
  8. Nov 19, 2018 at 7:53 AM
    smslavin
    Denver, CO
    left them a message last friday. trying again later today.
    just over a year
    nope, it's the 8100
    we'll see what they say. thanks.
  9. Nov 19, 2018 at 7:57 AM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    NM
    2017 TRD Pro Tundra DC Cement
    1 of 255
    It does sound like something haywire with the switchpros. Interested to see what they say.
  10. Nov 19, 2018 at 10:54 AM
    COTundraRoamer
    Dustin
    Denver, CO
    18' Platinum CM
    I have an 8100 in our Jeep. It's a super early production unit and overall has been fine but can be finicky. I think Bluetooth died on it as well. Curious to hear what they say.
  11. Nov 19, 2018 at 11:37 AM
    TheBeast The Beach
    tag for outcome
  12. Nov 19, 2018 at 11:45 AM
    Bailey
    Bailey Enjoy Every Sandwich
    Bailey
    Wandering The West
    2010 Tundra - Slate Grey - 4x4 Platinum
    You should be covered under the 2-year warranty. Hopefully, Switch Pros will take care of you and send you a new unit.
  13. Dec 7, 2018 at 7:05 PM
    smslavin
    Denver, CO
    So. Still trying to resolve this. Spent some time on the phone with Laura at SwitchPros. Super smart, super awesome and knew exactly what was causing what I described.
    Jumping a dead battery, overloads the circuit so more than 18a was going to the switch. When the BD bar came on, the SP shut off that circuit. She mentioned some other things but the only thing I caught was 12.5v needed from the battery.
    Also, when I originally installed the unit, I used one of the factory chasis grounds in the engine bay. Laura said bad idea. The SP needs to be grounded directly to the neg terminal on the battery.
    So, I disconnected the battery and moved the SP ground wire with the hope that would fix things. No go. Left a message for Laura and will try her again on Monday. Then i got a wild hair and decided to put a volt meter on the battery. It measured out at 12.35. The battery was dead for a week while sitting at the airport so maybe that has something to do with it.
    So, smart people, do I go pick up a new battery tomorrow and try again?
    Watt maker and TheBeast like this.
  14. Dec 7, 2018 at 7:27 PM
    TheBeast The Beach
    Watt maker and smslavin [OP] like this.
  15. Dec 7, 2018 at 7:31 PM
    smslavin
    Denver, CO
    Yea. That’s new. She said they updated the install instructions with the 9100...
    TheBeast likes this.
  16. Dec 12, 2018 at 11:00 AM
    smslavin
    Denver, CO
    the saga continues.
    spent almost 30min on the phone with laura and her husband. they walked me through putting a volt meter on a few points and everything measured out correctly. unit appears to be fine. could be possible ground issue with the 20" s8 on switch 3 since every other switch works without issue.
    i'm going to pull a few things apart and move the bar's ground from the chassis ground to the neg terminal on the battery. if that has no change, then i'm going to flip the switches for the 20" and 40" bars to at least see if the 20" bar comes on.
    @Baja Designs is there a way for me to self test the light bar? any other things i should investigate?
    i can't say enough about the support i'm getting from switchpros. above and beyond. awesome people.
  17. Dec 12, 2018 at 11:09 AM
    ColoradoTJ jberry813fanclub.com Staff Member
    White GMundra
    Fuzzy Mirror Dice
    On your battery, was that totally charged and disconnected?
    If so, yes, new battery.
    Grey Wolf and smslavin [OP] like this.
  18. Dec 12, 2018 at 11:10 AM
    smslavin
    Denver, CO
    yes. thinking about going to pick one up.
    NewImprovedRon and ColoradoTJ like this.
  19. Dec 12, 2018 at 11:21 AM
    White GMundra
    Fuzzy Mirror Dice
    831Tun and smslavin [OP] like this.
  20. Dec 12, 2018 at 11:29 AM
    White GMundra
    Fuzzy Mirror Dice
    Oh, and off topic, but Sean086 and I are installing a complete new lift, rear leaf pack, etc in the middle of Jan sometime.
    Wanna get those bypasses on?
    We can make it Sean(s) day.
  21. Dec 12, 2018 at 11:48 AM
    Baja Designs
    Baja Designs ENTER: "BDForums" coupon for your forum discount! Vendor
    San Marcos, CA
    One way to test the lightbar is to run it directly to the battery to confirm everything works 100%. Moving the ground to the battery instead of the chassis is a good move. Let us know if you're still experiencing issues. It's possible the bar is grounding through the housing and needs to be isolated from the bumper.
    Baja Designs
    www.bajadesigns.com
  22. Dec 12, 2018 at 4:41 PM
    Watt maker
    Ronald
    NM
    1 of 255
  23. Dec 12, 2018 at 6:07 PM
    smslavin
    Denver, CO
    thanks. i’ll have to check the measurements. the battery tray i have from @SoCalDave was built for odyssey’s.
    hell yeah. i’ve been trading PMs with @Sean086. :cool:
    i have a bottle of stranahan’s and one from feisty spirits distillery ready to go for you. we are in moscow from 1/13-1/21. depending on day job schedule, i should be able to make anything outside of that work. the week of new year’s will definitely be slow and quiet.
    rad. thanks for the input. i’ll hook it direct to the battery tomorrow and see what happens. isolating the bar might be a good idea. just a rubber grommet on the mounting tab?
    ColoradoTJ likes this.
  24. Dec 12, 2018 at 6:15 PM
    White GMundra
    Fuzzy Mirror Dice
    Sounds good Sean. We could squeeze you in before if we do some planning.
  25. Dec 12, 2018 at 6:18 PM
    smslavin
    Denver, CO
    let’s get to planning then. i’ll check with bec in the morning. need to get this stuff on so i can sell the old rear kings and get the alcan packs ordered.
  26. Dec 12, 2018 at 6:26 PM
    White GMundra
    Fuzzy Mirror Dice
    Do you have my number still.
    Let me know tomorrow.
  27. Dec 12, 2018 at 6:49 PM
    smslavin
    Denver, CO
    affirmative
  28. Dec 13, 2018 at 9:45 AM
    Baja Designs
    San Marcos, CA
    Rubber grommet would do the trick. Feel free to shoot me a text with what you find. You've got my #
    -Bailey
  29. Dec 13, 2018 at 10:39 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    ColoradoTJ and Watt maker like this.
  30. Dec 13, 2018 at 11:03 AM
    White GMundra
    Fuzzy Mirror Dice
    Yes sir
