GoPro Suction Mount
Discussion in 'Photography' started by newguy, Jan 18, 2020.
  1. Jan 18, 2020 at 6:55 AM
    newguy
    newguy [OP] New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Couldn’t really find any info on the forum about this. And I don’t really trust what I see on the Internet sometimes. So looking for some advice.
    I got myself a GoPro for Christmas. Part of the reason was to do some cool moving shots off-routing in the Tundra.
    Have any of you had any good experience with a suction cup mount for the outside of the truck? Or, Are there any other type of mounts that should be considered?
    TIA
  2. Jan 18, 2020 at 7:03 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  3. Jan 18, 2020 at 7:04 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I can’t imagine suction cups would stay on the truck very well on the outside of the truck...
  4. Jan 18, 2020 at 7:08 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The genuine GoPro suction mount has very strong suction. I could almost pull a dent with it. I've stuck it to my bed and went full speed through dirt roads, even catching some air, and it was still hard to peel off. That was with an older GoPro which was bigger and heavier than the ones out today. Aftermarket ones are surely cheaper but do you want to risk your $400 camera to save a few dollars?
    A good tip is to keep it sealed in a ziplock when not in use, or keep the suction surface covered in saran wrap. I used to do that on mine and the last time I used it I left it out in the open for a few years. Now the suction pad has a fine film of dust on it that I could probably clean off, but would be better if kept clean from the start.
    newguy[OP] and Pinay like this.
  5. Jan 18, 2020 at 7:08 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You underestimate how much they suck :D
    Pinay[QUOTED] likes this.
  6. Jan 18, 2020 at 7:42 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Sucking can be good :D
    Darkness[QUOTED] likes this.
  7. Jan 18, 2020 at 7:45 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Where on the truck did you attach??
  8. Jan 18, 2020 at 7:46 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Bob and Pinay like this.
  9. Jan 18, 2020 at 7:46 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Whoops, on the bed.
    Ever try up front??
  10. Jan 18, 2020 at 7:48 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I just find a flat surface and stick it on. I've done it on the bed, the door and the windows. Windows work well but fenders or doors are nice to watch your tires bouncing. The key is a flat surface clean of dust.
  11. Jan 18, 2020 at 7:51 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Bruce @papasmurf just posted not long ago cam footage inside his wheel well up front, I wanna say it was zip tied cuz with how fast he was goin and all the turns no way cam would stay otherwise.
    papasmurf and BravoDeltaRomeo like this.
  12. Jan 18, 2020 at 7:51 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I think the key here is genuine. We have an aftermarket one that came in a Costco kit, bought for other accessories and it barely holds on the inside of the windshield.
    Pinay likes this.
  13. Jan 18, 2020 at 8:47 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Inner wheel well shots can be done using the sticky mounts. Clean a spot on the frame with simple green, let it dry and apply a gopro sticky mount. Leave it on 24 hours before using.
  14. Jan 18, 2020 at 2:53 PM
    newguy
    Thank you all for your input. Tethering is the way to go for sure if doing a suction cup on the outside.
    I like the bed rail mount too but kinda pricey.
  15. Jan 18, 2020 at 3:05 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yeah, I don't know why it's so freaking expensive. It works out to be like $80 Canadian I'd you can find one.....it should be $30
  16. Jan 18, 2020 at 3:26 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    The GoPro brand suction cup base is great. I've used mine on the freeway and on trails. I stick it right on the windshield above the driver, its got an incredible hold.
  17. Jan 19, 2020 at 6:16 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    :D
    yup ziptied in :D
  18. Jan 19, 2020 at 6:19 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I would only attach it to the glass.
    Any real flex in a body panel could release the cup. :thumbsup:
  19. Jan 19, 2020 at 6:26 PM
    P-Factor
    P-Factor New Member
    Other options...
    2 exceptionally well designed mounts for mounting a camera on the outside of the aircraft.
    https://mypilotpro.com/
  20. Jan 19, 2020 at 6:29 PM
    TheBeast The Beach
    meh...my RAM suction cup mount kept falling off. Eventually I drilled the dashboard and added something more permanent.
  21. Mar 26, 2020 at 1:02 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    I own this product and use it all the time. I like that if fits the bed rail system but wish it has a swivel mount as well. It pricey but like other said, i've always found the OEM GoPro gear to be very high quality and it lasts for a long time. i've got a bunch of aftermarket that i've had to throw away or worse, almost had equipment failure.
  22. Mar 26, 2020 at 1:17 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    here are the mounts that i would consider...
    https://www.tackform.com/
    https://www.delkindevices.com/products/accessories/fat-gecko/
    not sure what you want to use it for but tackform has some nifty mounts for attaching to headrests. also, a mini gimbal that will work with hero 7 & 8.
    https://www.evogimbals.com/collecti...e-gimbal-for-gopro-hero-session-hero5-cameras
  23. Mar 26, 2020 at 1:28 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    @Navi
    The issue is availability. To get one shipped from USA places, it works out to $170 Canadian. No thanks
    If I could find it for $50-60 locally, I'd have no problem with that.
  24. Mar 27, 2020 at 12:37 PM
    Navi
    Navi New Member
    That makes sense, i missed that part. No way i would pay 170 CAD either. But, i like working with the GoPro products on the trail so i think getting some mounts makes sense if you're really going to use them
