Getting a Viper alarm system to work with the Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ubserved, Jul 8, 2017.
  1. Jul 8, 2017 at 3:36 PM
    ubserved
    ubserved [OP] New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    Hello everyone. I have a 2017 CM Platinum and was surprised that the top end model didn't have a remote start already. Anyways, I went to have an Viper 5806 alarm system installed with the remote start and they had it at their shop for three hours and then called me and said that the remote start has issues, that they called BEI which is the owner of Viper, Clifford, and other alarm system companies and was told that they didn't have the software figured out and that it might work, it might not work, that they had to program it as a 15 Tacoma to set it up then once configured set it up as a 11 Camry and that even then it might work and might not. Anyone have this problem and if so did you find a fix?
  2. Jul 8, 2017 at 5:23 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    My 2017 SR5 CM came with remote start, mind you it turns off when you unlock the truck, which is annoying.
    Sorry that I can’t answer your question.
  3. Jul 8, 2017 at 11:02 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    I have the Viper 5906 and it works perfect.
  4. Jul 9, 2017 at 2:44 AM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    I am going to go with they don't know what they are doing. My dealership is an Automate dealer. Automate uses the same brains as Viper. I install these on Tundra's all the time. Its the same software(TL5) that has been used since Toyota changed to the 80 bit G-key. What are the issues you are having? I have been doing 12v for over 20yrs. I am not sure where you are located, but if you are near by I would gladly help you.
  5. Jul 9, 2017 at 3:42 AM
    PMG
    PMG New Member
    I have viper as well without issue. Be sure to use a viper installer.
  6. Jul 9, 2017 at 5:57 AM
    sstoddard
    Shawn
    2019 Crewmax Sport
    Look under your dash and see if its a wiring nightmare. If it is get your money back and go to a reputable installer
    NewImprovedRon likes this.
  7. Jul 9, 2017 at 7:54 AM
    ToyotaTundraMike
    2015 Tundra
    Same thing happened to me at Best Buy. Let them try it twice and they couldnt ever get it to work. Finally said to hell with it and got my money back. Still really wish I had remote start...
  8. Jul 9, 2017 at 10:41 AM
    ubserved
    Michael
    They were a viper certified installer. I am in Salem Oregon. My CM came with the basic alarm system from Toyota. I was thinking last night of contacting my dealership and upgrading to the VIP Alarm system from Toyota and do the remote start through the dealership as well. It would cost a little more but then be warrantied through Toyota. What are your thoughts on that? I also did get my money back from the viper installers btw. They were really apologetic over it all. Now I wonder if they even attempted it, perhaps it was a wiring nightmare under there and they said screw it. Who knows. I just want the truck better protected before I take my next road trip that's coming up.
  9. Jul 9, 2017 at 11:15 AM
    ubserved
    Michael
    Actually I have an addition question. I know Viper was bought by Clifford, and Clifford was bought by NEI, I know the alarms are similar. Is one better than the other?
  10. Jul 9, 2017 at 11:32 AM
    Mike Tread lightly.
    south carolina
    Wrong ...
    It's all owned by direct electronic inc. or dei. It has been that way for YEARS.. they are a world leader.
    To me your installer has no idea what they are doing. Just saying.
  11. Jul 9, 2017 at 3:01 PM
    ubserved
    Michael
    I meant DEI, not NEI. My secondary question still remains, is Clifford and Viper the same or is one better than the other?
  12. Jul 9, 2017 at 8:58 PM
    boloson
    boloson New Member
    They are the same. Part numbers are only off by a letter. I requested a viper but my mechanic was able to get me a Clifford for cheaper & the part numbers only differed by a letter. They also looked identical & all owned by dei so they most likely use interchangeable parts. My installer also had issues with mine & their tech support forwarded install instructions for a 4Runner. The 4Runner install worked & ended up discovering a defective brain in the process. Brain was replaced & Works great now but it was a painful process.
  13. Jul 9, 2017 at 10:59 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Good luck with this. I am interested in the remote start for my 2011. I'm in Beaverton and would be interested in knowing which direction you go.
  14. Jul 10, 2017 at 12:40 AM
    ubserved
    Michael
    I am going to check on the VIP Alarm upgrade via the dealership Monday and I am going to go over to cartoys in Salem as well. I will let you know what I find. Cartoys deals with Clifford mostly. I might go with the clifford option as opposed to the toyota option being I want a sensor for my tonneau cover and I seem to recall toyota won't or can't do that. Either ways....stay tuned.
  15. Jul 10, 2017 at 7:16 AM
    MTwiford
    MTwiford The second mouse always gets the cheese
    2025 Platinum TRD Magnetic Gray
    Had mine installed with smart start as well. Works perfect. I think you need to try another installer. Definitely get your money back.
  16. Jul 10, 2017 at 9:05 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    I had a Viper remote start / alarm installed on my TRD Pro 3 weeks ago and it works perfectly. They did take a LONG time to install but it works great! Took mine to a certified Viper Installer, I know you said you did too but try a different place.
  17. Jul 11, 2017 at 10:36 AM
    sstoddard
    Shawn
    2019 Crewmax Sport
    Just because they are a certified Viper installer does not mean they know what they are doing. The training classes only cover the basics. The install is based on the individual. I guarantee it's not done properly. Tundras are not the most difficult to do.
  18. Jul 11, 2017 at 11:05 AM
    ubserved
    Michael
    If you read one of my earlier posts, you will see that I did check with them yesterday. Unfortunately they don't have an option to add a sensor for my tonneau cover. Yes I realize your comment was sarcasm. 8)
  19. Jul 11, 2017 at 11:15 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Except that Toyota's remote start is horrible. You start it and when you open the door to get in, kills it.
  20. Jul 12, 2017 at 8:17 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    I have a 2014 CM with a dealer-installed Viper Model 7756v with the 2-way remote. I got the truck in 2015 & everything worked perfectly. Around the tail end of this past winter my remote start quit working. The truck's computer thinks it's running & wont let you manually start the vehicle until you kill the remote start with the remote. Recently, I've been getting feedback on the remote stating that the trunk is open when I try to arm the system. This is all in addition to the frickin door lock actuators failing sequentially. Anyone have any suggestions?
  21. Jul 12, 2017 at 10:51 AM
    PMG
    PMG New Member
    Viper has a lifetime warranty on the unit and your dealer should have a warranty for the installation..
    Anyone with a viper retain the functionality of opening the driver door with 1 click and all doors with 2 clicks?
  22. Jul 12, 2017 at 11:21 AM
    ToyotaTundraMike
    2015 Tundra
    What an excellent contribution. Thank you for your well thought out comment.
    GlobalGuy and NewImprovedRon like this.
  23. Jul 12, 2017 at 2:41 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    That can all be done in programing
  24. Jul 12, 2017 at 4:55 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    If all your looking for is a remote start, I recommend the Fortin Evo One with the T harness. Seller on fleabay will flash it to your vehicle and install isn't to difficult, and you keep your factory fob.
    https://www.tundras.com/threads/remote-start.8480/page-2
  25. Jul 12, 2017 at 6:09 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    Only problem going that route is range
  26. Jul 12, 2017 at 7:21 PM
    Tundra Fan
    Toby
    For the Fortin??
  27. Jul 12, 2017 at 7:23 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    It only has the range of the factory remote. A 100ft or so.
  28. Jul 12, 2017 at 7:26 PM
    Tundra Fan
    Toby
    Yeah, thats true, but after the range my last vehicle had, I think approximately 100 feet is incredible. I damn near had to be on top of my last car to get it arm/disarm.
  29. Jul 12, 2017 at 9:36 PM
    ubserved
    Michael
    Update. I checked with the dealership for the upgraded alarm systems from Toyota, they won't install a sensor for the tonneau cover because that's a modification much to the irritation of the accessories manager. The service department won't do it period even though the mag switch they use for the hood would be just as fine for the tonneau. I even asked if they skipped the hood switch and place it for the tonneau and they were like I was asking them to go stand in front of a train or something. So I will get a viper installed somewhere, I can go to what I have determined is a best recommended shop here in Salem while a bit on the high price side are basically considered the gold standard or when I take a trip back to the CA next month I will go to the place that put in my last few alarm systems. I appreciate most everyone ones suggestions.You all are the best.
  30. Jul 13, 2017 at 2:53 AM
    sstoddard
    Shawn
    2019 Crewmax Sport
    I can walk you through adding the switch to the factory system if you want
