Getting 35" Tires with 2.5-3 in rough country leveling kit, will it fit??
Discussion in 'Wheels & Tires' started by bdalton88, Jun 28, 2016.
  1. Jun 28, 2016 at 8:45 AM
    bdalton88
    bdalton88 [OP] New Member
    Brad
    2015 White Tundra SR5 CrewMax 5.7 L V8 4x4
    Line X grill & bumpers/Westin ProTraxx 4" Oval Nerf Bars/Stampede RuffRiderz Fender Flares
    I have a 2015 Toyota Tundra Crew Max SR5 5.7 L V8 4x4 that I want to get 35" Nitto Trail Grappler tires with the Rock Star 18" matte black rims on a 2.5-3 in Rough Country Leveling kit. Will I have any issues with these rubbing or not fitting properly? I just want to make 100% sure before I go through with the purchase. Thanks.
  2. Jun 28, 2016 at 9:22 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    it all depends on your offset I'm running 35x12.50's on a 18x9 +20mm offset with about 1.5" of lift up front with nearly no rubbing.
  3. Jun 28, 2016 at 10:37 AM
    bdalton88
    Brad
    What is offset? How does that work?
  4. Jun 28, 2016 at 10:45 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    T-Rex266 and jberry813 like this.
  5. Jun 28, 2016 at 4:11 PM
    ARamirez73
    ARamirez73 RIDIN' THE RAILS ON A CRAZY TRAIN
    THE LONE STAR STATE...TEXAS
    2014 CM TSS MGM 4WD SR5 5.7FF
    Rough Country 6" lift / 35x12.50R20 Cooper Discoverer ST Maxx/ 20x9 +20 Fuel wheels "Mavericks" (Came with) / S&B CAI/ 2-10" Rockford Fosgates R2/ Massive Audio Nano N2 amp (Came with)/ KatSkins seat covers (Came with)/ Weathertechs window vent visors and floor mats/ 1A-AUTO.com aftermarket tow mirrors/ Undercover tonneau bed cover/ Viper alarm 3305V/ Flowmaster Super 40 Dual in-out/ 40" led light bar/ TRD Pro grille/Rough Country 30" LED light bar/TRD rear sway bar/ Ranch Hand legend grille gaurd
    I jus got edumicated...lmao wheels 101
    GNTundra likes this.
  6. Jun 28, 2016 at 4:24 PM
    Boondockshydro
    Boondockshydro New Member
    Will
    Tundra
    I'm running 275/65/20 on 2008 sr5 crewmax tire is 34.1" tall. I have a motofab level lift 3" front and 2" rear and my tires will just barely rub if I turn all the way.
    CaptTyler likes this.
  7. Jun 29, 2016 at 10:43 AM
    bdalton88
    Brad
    How high would I need to get it lifted with no rub? This is what I am looking at getting:
    4 - Ulra Gauntlet Bolt 198B 18x9 5x150 25
    4 - Nitto Terra Grappler G2 LT35x12.5R18
    Would a 3x2.5 rough country leveling kit work or am I looking more at a 6 inch lift? Let me know. Thank you.
  8. Jun 29, 2016 at 11:55 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    I know a number of people are running 35s with 2.5-3" of lift. I think you just have to trim or bend the skid plate a little to avoid rubbing. As for the lift, I would recommend going with a better setup than the spacer kit. Especially if you plan to take the truck on rough roads or off-road.
    rons23 and jlee like this.
  9. Nov 7, 2016 at 10:58 PM
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    Did you ever get those ultra gauntlet rims to fit with your lift kit without any issues.
    I found a set used online and want to use it for my winter tires/rims but I have a 3" lift on my truck and am worried about fitment as its not one of the rims listed for a tundra with a lift.
    Anything you can share should be helpful.
  10. Nov 7, 2016 at 11:23 PM
    Law323
    Law323 Workout gloves? You mean sissy mittens??
    Law
    Tennessee
    2012 4.6 L MGM DC
    Toytec BOSS suspension lift @ 3" (front) Toytec BOSS remote resi's (back) 1" Toytec block (rear) 275/70r18 Toyo AT2 Info system mod 3D MAXpider Kagu floor mats LED interior lights 50% ceramic tint front windows 35% ceramic tint windshield brow Bed mounted YETI bottle opener Paracord wrapped oh Sh!t bars 3" stubby antennae Upcoming: LED backup lights/cargo lights OEM Backup camera Method Standard 18x9 wheels Iron Cross Patriot step bars TRD sway bar Trifold or roll up tonneau cover
    I wouldn't go rough country spacers.
    T-Rex266 and rons23 like this.
  11. Nov 8, 2016 at 5:57 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2017 MGM CM Limited 4WD
    in signature
    It is more of the wheel offset and tire size that causes rubbing. There is a guy on TT who was running 35's with NO lift and NO rubbing...but he was running Rock Warrior wheels that have a +60 offset.
    Typically, rubbing occurs on the body mount and/or front wheel well liner. So, regardless of how high you go, the tire will rub at those locations if the offset and tire size are such that those come into play. If you want to avoid rubbing, stick to somewhere around +30 or +35 wheel offset. The way the wheel well is shaped, keeping to a less aggressive wheel offset (higher number) will keep the wheel tucked into the wheel well; thus avoiding the aforementioned areas where more aggressive offsets hit.
    joonbug and Law323 like this.
