Gerbings (Gyde)/Warm & Safe Gear - Amperage from accessory plug
Discussion in 'Off-Topic Discussion' started by MJoeP, Feb 14, 2021.
  1. Feb 14, 2021 at 8:06 PM
    MJoeP
    MJoeP [OP] New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Wasn't sure where to post this....so I'll drop it here.
    I'm an avid motorcyclist and ride almost year around, excluding snow and icy weather; although, I've been caught in a snow storm on my way back home. So, I have heated gear (heated seat, heated grips, heated jacket, heated pants, and heated gloves). The gear gets warm almost instantly. One piece of gear I have is a heated jacket liner.
    So now my question, with the cold temps of late and ice and snow, I'm driving the truck and would like to use my jacket liner until my truck warms up.
    Can anyone tell me how many amps can I draw through the accessory plug in the dash (2016 Tundra) where I currently have a dual usb charger/adapter plugged in now?
    The heated jacket liner draws a max of 6.4 amps.
    Here is the adapter I plan on using (assuming too that it is the correct size for the outlet)
    https://www.gerbing.com/temp-adapt-plug
    I won't be using a heat controller like I do on my bike to turn the heat up and down. I'll just unplug it when I get warmed up or the truck is warmed up.
    Jacket liner
    https://www.thewarmingstore.com/gerbing-gyde-12v-heated-jacket-liner.html
    Warm & Safe didn't exist when I first got my Gerbings gear (Gerbings in now Gyde) but I've read and heard that their gear is superior.
    https://www.warmnsafe.com/collections/12v-for-motorcycling-power-sports
    ANOTHER Option:
    I may just power the liner from my Microstart AntiGravity Battery
    https://antigravitybatteries.com/products/micro-starts/xp-10-hd/
    YardBird likes this.
  2. Feb 14, 2021 at 8:45 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Sounds like a great idea. Keep us posted with your results.
  3. Feb 14, 2021 at 9:53 PM
    MJoeP
    Joe
    2016 Tundra 1794
    I just tried the AntiGravity battery. It works great, max output for the plug needed is 10amps. The one caveat is that it only stays on for 1 minute, then shuts itself off. I found this to be the same when trying to charge my cell phone on long rides with it.
    YardBird[QUOTED] likes this.
  4. Feb 14, 2021 at 9:59 PM
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    Most of the outlets should have a maximum wattage stamped into their cover. I think all of my accessory plugs are fused at 10 amps but I also think there are at least 2 separate circuits which would be 20amps total.
    MJoeP[OP] likes this.
