General Supercharger Thread
  1. May 6, 2026 at 6:38 PM
    JohnWhicker
    JohnWhicker New Member
    2021 SC Tundra 2013 SR5 Tundra 2010 RCSB Tundra
    Yeah I may have to do it on the SC 2021 first but my RCSB will be my SC daily. I think I am gonna do it in phases. So many decisions to make and money to waste. O well, such as life.
  2. May 6, 2026 at 7:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Good info. One downfall is how Toyota started modulating the line pressure for mpg. Even though line pressure increases with load it still allows for a increase in allowable slippage as HP increases.
    e30cabrio likes this.
  3. May 6, 2026 at 7:07 PM
    centex
    centex New Member
    Are you talking about the flex lock or something else? The flex lock is easy to tune out so it’s not functional. It’s either locked or not.
    HulkSmurf14 and e30cabrio like this.
  4. May 6, 2026 at 7:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you occasionally do spirited driving and not a burnout sideways kinda driver you should be good. The VB upgrade is extra insurance with yearly to 20k atf changes. Debri is the VB killer. Magnefine filter can helpout too.
  5. May 6, 2026 at 7:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've had Flex lock disabled for a few years. The SLT modulates line pressure from minimum to maximum pressure. I've made some adjustments to the trans that I could. I have a line pressure gauge that I look at. It drops psi right before a shift. My minimum is about 12psi and max about 125psi.
  6. May 6, 2026 at 7:14 PM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    Or.... you could just gather a few more SC'd Tundras, and you could host your own group buy and negotiate free shipping... :evil:
  7. May 6, 2026 at 7:28 PM
    JohnWhicker
    What a great idea. I would definitely consider that option :bowdown:
  8. May 6, 2026 at 7:35 PM
    centex
    centex New Member
    Dang that’s a swing. I understand the logic though. Smoother shifts and easier on parts. Not good for performance though.
  9. May 6, 2026 at 7:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  10. May 7, 2026 at 11:53 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mine definitely doesn't shift that smooth... I'm still rocking VFt Orange Virus shenanigans...
    Tripleconpanna likes this.
  11. May 7, 2026 at 5:50 PM
    JohnWhicker
    For my future Magnuson 2650 install here is a question on the OTT tune or any other tunes line SNIV for that matter.
    As I am planning to go with bigger fuel pump, injectors and 76mm sniv pulley, can I cap the tune at 550, keep it very conservative until I decide to beef up the transmission with a valve body, down the road as I am doing everything in phases. And after the valve body is installed then I can let the tune rip and go to the max?
    What do you think? Doable?
  12. May 7, 2026 at 5:54 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The tune can't dictate the max pressure. Either you need to leave the pulley alone or never go over 1/2 throttle.
    There has been discussion of a boost controller, I don't remember how that was sorted out.
  13. May 7, 2026 at 6:04 PM
    JohnWhicker
    How about go with the bigger fuel pump and bigger fuel injectors and leave the pulley alone until I beef up the transmission. Would this setup be easily tuned by OTT or SNIV?
    And when I do the transmission then I swap the pulley to 76mm and let it rip tune.
  14. May 7, 2026 at 6:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Very doable with stock pulley and upgrade the injectors and pump with the tune. When your ready for smaller pulley they can up the PE and timing, if needed, after a data log.
