General Supercharger Thread
  1. Mar 2, 2026 at 12:48 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Would you consider any trades? Many interesting things available, but a 4 seater street legal golf cart would be my first offer.
  2. Mar 2, 2026 at 12:50 PM
    memario1214
    Colton
    Gilbert, AZ
    '21 Limited MGM CrewMax
    :wave: Right here to hook ya up!
    :fistbump::fistbump::fistbump:
  3. Mar 2, 2026 at 12:50 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Don't lowball him, he knows what he's got!!!
  4. Mar 2, 2026 at 1:08 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Please send pics of the payload sticker so I can evaluate if this is feasible.
  5. Mar 2, 2026 at 1:12 PM
    Silver17
    Northeast
    I did not need to hear his opinions as I opine getting into a truck with a 10 speed.
    Paraphrased: what’s the right amount of gears for a transmission? Answer: not 10. :oops:
    Guess there’s always a CPO 6 speed.
  6. Mar 2, 2026 at 1:36 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra 2650, 2012 Tacoma TRD s/c
    So did I. Colton is a good dude.
    I had to warranty the crossover pipe and Magnuson shipped it out next day, no issues. They just asked for the Hotshot invoice number and purchase date.
  7. Mar 2, 2026 at 1:41 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    When I was having IPT rebuild the trans we talked about the 6 and 10 speeds. He echoed a similar statement about EPA mandates striving for fuel efficiency but transmissions were failing in the longevity field.
  8. Mar 2, 2026 at 1:46 PM
    centex
    centex New Member
    What's not failing long term in the chase of fuel economy numbers?
  9. Mar 2, 2026 at 2:32 PM
    Calvin (NC)
    Calvin (NC) New Member
    NC
    2017 Limited Double Cab FFV MGM
    RSI SmartCap, chrome delete, lightbar in bumper, intake, dual exhaust
    Just ordered!
  10. Mar 2, 2026 at 2:38 PM
    JohnWhicker
    JohnWhicker New Member
    2021 SC Tundra 2013 SR5 Tundra 2010 RCSB Tundra
    Hotshot Offroad. Hit @memario1214 here on the forum. He will give a great deal. He really took care of me.....
    e30cabrio, daria, HulkSmurf14 and 2 others like this.
  11. Mar 2, 2026 at 2:45 PM
    memario1214
    Colton
    Gilbert, AZ
    :bananadance::bananadance::burnrubber::burnrubber:
    Thank you sir!
  12. Mar 2, 2026 at 2:51 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Sounds to me like he has a truck he doesn't want. :p
    Tripleconpanna and HulkSmurf14 like this.
  13. Mar 2, 2026 at 3:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    @memario1214
  14. Mar 2, 2026 at 7:07 PM
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    So after driving a few times, I'm noticing during some hard throttling and medium to medium-high boost that my Innovate PSB-1 gauge is giving me the "O2 Cut" message early in the boost. I know that doesn't actually do anything for our setups, but it got me noticing that the AFR's tend to be a little slow to catch up with the boost. Is that delay normal?
    I need to try it again a few times and actually count, but I think it's taking 2-3 seconds of constant boost (3-4 psi+) to get the AFR to really drop below 14.
    e30cabrio likes this.
  15. Mar 2, 2026 at 7:17 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Entirely depends how the tune is setup. What throttle level power enrichment (or other fueling logic) is set to engage, as well as what the delay timers (if any) are set to. Best to ask your tuner since they're all different
  16. Mar 2, 2026 at 7:26 PM
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    Just running the stock Magnuson tune at the moment.
  17. Mar 2, 2026 at 7:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That O2 Cut message is programmable, that info should be in the manual for it.
    HulkSmurf14 and Greyota[QUOTED] like this.
  18. Mar 2, 2026 at 7:44 PM
    AZTundra
    Paul
    Phoenix, AZ
  19. Mar 2, 2026 at 7:57 PM
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Stumbled across this FB ad. If his work is legit, that price seems 2 good 2 be true no? Of course, I am sure it doesn't include removal/installation.
    e30cabrio and HulkSmurf14 like this.
  20. Mar 2, 2026 at 8:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was thinking this:
    3.1.1 Configuration using PSB-1’s interface buttons
    1. From the main screen, press and HOLD the left interface button to
    put the gauge in setup mode
    2. Pressing either the left or right interface buttons will allow you to
    cycle through the 10 different setup parameters in the menu.
    3. Once the desired setup parameter is displayed, press and HOLD the
    left interface button to make a change. Once the parameter’s
    configuration has been entered it will start flashing.
    4. Make changes by using the left or right interface buttons.
    5. Once in setup mode, pressing and HOLDING both interface buttons
    together will move you to the main screen. The gauge will revert back
    to the main screen if no there have been no button presses for 15
    seconds.
  21. Mar 2, 2026 at 8:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If legit that's pretty good. What frictions/brakes are they using? Are they using standard Transgo or reaming and using oversized valves/ relays if needed. A built valve body is around $900 and a good friction rebuild kit about $1000. So it's a possibility. Especially most are going for $6-$7000, not including removal/install.
    My local shop wanted $6500 for a built ab60 using what I spec'd.
  22. Mar 2, 2026 at 8:48 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm assuming everything would be OEM except the shift kit, but if someone were to hand him the beefed up VB I'm thinking they wouldn't have a problem installing it.
  23. Mar 3, 2026 at 3:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm going to drop some uneducated data here.
    it's what I base my method(s) on.
    I can easily break my transmission (as some of you have demonstrated)
    Of all the things that I can do to assuage my transmission frailties, I choose to keep it cool.
    I have some mechanical & electrical knowledge....and that knowledge tells me the same thing this transmission dude said.
    <yes, confirmation bias plays a part>
    keep it cool
    change the fluid
    put in a hoonage type valve body (on my list)
    now, I am also quite the knucklehead and do NOT listen to internet "engineers"
    <"The toyota engineers knew what they were doing when they REMOVED MY COOLER">
    fuckabunchathat
    those folks do/say shit based on what they hear...never to dig into the details.
    to have someone tell me it's OK to run a Toyota transmission @ 230 degrees is learning disabled.
    shit, choosing to run it at 205 when you could easily run it at 170 is retarded.
    When I say I run my kit @ 150-170, I do so because it makes damn sense to run it as cool as possible.
    in short....
    pin your thermostat
    D&F every 30k
    get a valve body
    and,
    It's damn nice that we shifted off of winter blend gas
  24. Mar 3, 2026 at 5:17 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I got more info:
    They are using Alto Clutch Kit, Alto Piston Kit and are only reaming the TCC Relay Valve. They also replace the "Plugs" , and put in the Transgo Pressure Regulator Boost Valve kit.
  25. Mar 3, 2026 at 6:01 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Not terrible for the $4k price tag...
    texasrho83 and e30cabrio like this.
  26. Mar 3, 2026 at 7:15 AM
    e30cabrio
    USPS delivered my ecu to OTT yesterday, @JustDSM will return it today and USPS willing I'll have it Thursday. I have severe boost withdrawals. Being Treeless for 2 weeks sucks.
    I got a super high quality USB and plan to run RJ45 to the laptop going forward.
    Also, all this transmission talk has me seeking the valve body, I messaged C&CO yesterday. Do I want Nomad or Extreme?
  27. Mar 3, 2026 at 7:35 AM
    HulkSmurf14
    2014 Tundra Limited
    Go extreme...
    Tripleconpanna and e30cabrio like this.
  28. Mar 3, 2026 at 7:56 AM
    centex
    centex New Member
    Extreme all the way. There’s a little more firmness on the 1-2 and reverse but otherwise it’s no different than stock.
  29. Mar 3, 2026 at 8:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  30. Mar 3, 2026 at 8:04 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL 2 weeks cute
