Gen 1 Sub Woofer
Discussion in '1st Gen Tundras (2000-2006)' started by melloa, May 1, 2020.
  1. May 1, 2020 at 4:02 PM
    melloa
    melloa [OP] New Member
    Al
    2005 Tundra DC SR5
    So got my Gen 1 and as I do to all my cars, started the stereo upgrade - you know ... Atlanta traffic :(
    Nothing too over the top, as I listen more jazz and Bossa Nova:
    - JVC Receiver
    - Couple Amps
    - New speakers
    - Sub under the back passenger seat
    The little cargo area was acoustically insulated with kilmat, customer build a top to close the space and hold the woofer.
    So far so good, all working.... let's go inside for a bear ... put the seat down with the music playing and vraaaaaaa vraaaaaaaaaa vraaaaaaaaa ... noise starts coming from the seat plastic cover under it.
    So ... has anyone run into that and found a solution? I'm thinking of removing that and fill with lots of foam to create some pressure, to avoid the material to vibrate, but not sure will work.
    Any ideas will be appreciated.
  2. May 1, 2020 at 8:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    pull the plastic and throw some sound deadener in there. should kill the resonance of the plastic
    Darkness likes this.
  3. May 1, 2020 at 9:35 PM
    melloa
    Al
    2005 Tundra DC SR5
    Will do tomorrow and let you guys know results. Thanks :)
  4. May 2, 2020 at 8:52 PM
    melloa
    Al
    2005 Tundra DC SR5
    So, removed the bottom plastic cover from the seat and put several layers of kilmat until I had enough to stop the vibration. It did work.
    On side note, don't expect lots of bass from that kind of setup. It got a little better, but I'll be researching other speakers for the doors for better quality.
  5. May 2, 2020 at 9:20 PM
    Blueranger501
    Blueranger501 New Member
    Rear passenger conversion? I fiberglassed the inside, never had an issue, 15+ Years, running an infinity kappa perfect 10” w 300x1 bridged from my Kenwood X450-4.
  6. May 3, 2020 at 12:05 PM
    melloa
    Al
    2005 Tundra DC SR5
    The issue I had was vibration, not sure if that's what you are referring to. My problem is that I'll not get the same bass clarity when comparing with my RAV. That one has 600W x 4 for the doors and 400W mono for the kicker 12" sub box.
  7. May 3, 2020 at 1:15 PM
    Blueranger501
    If you don’t have a sealed box it won’t work properly. Just putting it in the compartment won’t cut it. I bet if you put it in a sealed box in the cab it would sound much better (or seal the compartment like I did).
  8. May 3, 2020 at 5:22 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I cut the plastic out on the bottom on mine and sealed the compartment behind the drivers seat with sound deadening mat and have 2 8's, it sounds great.
    Darkness and 2truckornot2truck like this.
  9. May 3, 2020 at 6:49 PM
    melloa
    Al
    2005 Tundra DC SR5
    As per my OP, it is sealed.
  10. Aug 3, 2020 at 8:38 PM
    2truckornot2truck
    2truckornot2truck Aspiring Truck Guy
    Felix
    TX
    2006 Tundra DC SR5 V8
    None yet! Does steering wheel cover count? :)
    Can you share pictures of this? Thanks.
  11. Aug 3, 2020 at 9:00 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
  12. Aug 3, 2020 at 9:08 PM
    2truckornot2truck
    Felix
    TX
