GCWR
Discussion in 'Towing & Hauling' started by Traveling Circus, Sep 3, 2018.
  1. Sep 3, 2018 at 5:38 PM
    Traveling Circus
    Traveling Circus [OP] New Member
    Greg
    2008 Tundra Double SR5
    Im searching for the GCWR for a 2008 Tundra and hoping someone can point me in the right direction.
  2. Sep 3, 2018 at 5:41 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  3. Sep 3, 2018 at 5:43 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  4. Sep 3, 2018 at 6:12 PM
    LML 3500HD
    Owners manual will have this information.
    I think your Gross Combined Weight Rating is 16000 lbs.
    831Tun likes this.
  5. Sep 3, 2018 at 6:20 PM
    Traveling Circus
    Greg
    Thanks TJ. It wasn't in the owners manual and not included on the door jam plate. Ive read other posts using the 16,000 as gcwr but no reference as to where the info was located. I pulled my specs on Toyotas site using the VIN, everything but gcwr and ghwr was listed.
    ColoradoTJ likes this.
  6. Sep 3, 2018 at 6:29 PM
    LML 3500HD
    Page 494-5 in your owners manual.
  7. Sep 3, 2018 at 7:41 PM
    Traveling Circus
    Greg
    Found it, 16,000 lbs is the gcwtr. My manual doesn't have a page 494-5, but your advice gave me doubt, so I went thru the manual again, it was located on page 484.
    Sometmes I work to hard on making simple things harder.
    Thanks again.
    Greg
  8. Sep 3, 2018 at 7:46 PM
    LML 3500HD
    I forgot my manners as well. Welcome to the site Greg.
    Glad we could get this sorted out. Obviously you understand the importance of this limit.
    I was on a PDF copy of the 08 Tundra owners manual.
    What are you planning to tow?
  9. Sep 3, 2018 at 8:00 PM
    Traveling Circus
    Greg
    Thanks for the welcome, I learn a lot and get really good ideas from these forums.
    I tow a 37' TT, dry weight listed is 7650, TW 750. I've been towing this for about 2 years. I've had two blow outs in three weeks. Put a set of the new Goodyear Endurance tires on today. Also weighed at a Cat Scale today for the first time, numbers were balanced good, total axel weight was 15,060. We live in N Florida, and mainly camp in the in the area, good flat roads, towing and stopping is not a problem. When we camp, i always like to see how many others are smart and use a Tundra for the TV. Usually there are only a few smart ones around. We love our 08 Tundra.
  10. Sep 3, 2018 at 8:37 PM
    LML 3500HD
    Well that's a lot of trailer, but in FL, it probably works pretty good. Was your TW actually 750 lbs at the scales?
    Where the first two tires that blew out on you from the same side?
    landphil likes this.
  11. Sep 4, 2018 at 3:03 AM
    Traveling Circus
    Greg
    How do I check TW? Same axel, opposite sides.
  12. Sep 4, 2018 at 6:04 AM
    LML 3500HD
    To check tongue weight, you can:
    -purchase a TW scale
    -when at the scale, pull vehicle only on scale. Disconnect trailer (obviously the trailer jack cannot be on scale), see how much weight you lose. You can also just pull the towed vehicle onto scale, disconnect with just the jack on the scale (chock tires) and pull tow vehicle off scale.
    On the tires: when towing, is trailer level? I see TT not level a lot and this overloads one axle, and can cause issues.
  13. Sep 4, 2018 at 2:06 PM
    Traveling Circus
    Greg
    Thats a good point, the trailer and truck are level and the Tundra tows it smooth. This is our 2nd TT and the first issue we have had with tires. I really believe it was caused by the low quality tires that was on the TT.
  14. Sep 8, 2018 at 7:38 AM
    Traveling Circus
    Greg
    I purchased the Sherline Hitch Weight scale. The real hitch weight is 1,157, which is about 13-14% of the loaded TT weight.
  15. Sep 8, 2018 at 7:45 AM
    LML 3500HD
    Just a bit more than was advertised right?
    I hope everyone sees this thread. The tongue weight advertised is often not what actual tongue weight is.
    Thanks for checking it out to get real world numbers Greg. Very smart decision.
  16. Sep 8, 2018 at 8:23 AM
    Traveling Circus
    Greg
    My guess is that the TW listed doesn't include 2 propane tanks and the battery. Plus my Hensley hitch adds another 190lbs. Still without all of that, the TW is 140lbs more than listed, or about 19% more.
    It goes w/o saying, the payload is tapped out, without any cargo in the bed of the truck.
  17. Sep 8, 2018 at 8:35 AM
    LML 3500HD
    I would agree. Your TW is pushing my 1 ton limits of 1500 lbs TW:eek:
