Gas Station Pump Shuts Off
Discussion in '2nd Gen Tundras (2007-2013)' started by haggis444, Mar 13, 2020.
  1. Mar 13, 2020 at 9:24 AM
    haggis444
    haggis444 [OP] New Member
    Cincinnati
    2010 Silver Double Cab 4x4 5.7L
    I have a 2010 5.7L with the smaller (I think maybe 26G) tank. All of a sudden I have to fill it up very slowly. Basically I can't take the pump nozzle and lock it on, and when I do hold it myself I have to do it slowly.
    I read that maybe the evap hose is clogged, but under the truck there are two hoses of the main fill hose. One is the size of a pencil, the other maybe the size of a big marker. Which one is it?
    And I really just thought through this, when this happens it almost sounds like a normal fill-up does when the tank is full. Like there is liquid rushing up the fill line.
    Any ideas of where to start? Thanks in advance.
  2. Mar 13, 2020 at 11:51 AM
    iRenaissanceMan
    iRenaissanceMan New Member
    Are you getting any check engine light or codes? I had this exact problem on my gen1. Ended up having to replace the evap canister. I tried various ways to "dry" or "clean" the cansiter... No joy. Had to buy new one which immediately resolved the problem.
    Blueknights75 likes this.
  3. Mar 13, 2020 at 11:55 AM
    Blueknights75
    Ron
    Clayton, NC
    New evap canister needed...
    Kerch71, BENWALES and iRenaissanceMan like this.
  4. Mar 13, 2020 at 12:02 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sometimes it's the shitty pumps. I get that sometimes on rental cars when traveling to other states. Or perhaps not; just throwing it out there.
    iRenaissanceMan likes this.
  5. Mar 13, 2020 at 12:05 PM
    iRenaissanceMan
    Could be. Definitely worth a shot before blowing a hundred or two on a used canister. New is much more.
    I would suggest eBay for used if you want to go that route for canister.
    TXMiamiFan[QUOTED] likes this.
  6. Mar 13, 2020 at 12:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My 2010 has done this since day 1. Ive noticed if im below 1/4 when i start pumping it usually works ok
  7. Mar 13, 2020 at 12:26 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I've had these issues as well, at one point for a week straight where I would fill $20 at a time, but just like it arrived it went away...
  8. Mar 13, 2020 at 1:14 PM
    haggis444
    Cincinnati
    Thanks for the replies everyone and for all the suggestions, it happened at multiple stations but did seem to be older pumps. So I don't think its the pump but I am driving 4 hours Saturday and will try and find some nice-ish gas stations to see if that makes a difference. And no code at all, no check engine light.
  9. Mar 13, 2020 at 4:08 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    most likely charcoal canister is full. if you had the large tank i would look at the anti roll valve as that is an issue on the 38 gallon tanks, but i have not heard of it being an issue on the 26 gallon tanks. with multiple stations being the issue, i doubt it is the stations pump. i would see if someone has a vacuum pump and can truly diagnose it first as the canister is $400 and up. make sure when you are filling up, you are not topping off. this is one way to fill the canister up quick
  10. Mar 13, 2020 at 4:16 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    This is exactly why you’re not supposed to top off the tank. When the evap canister gets replaced be sure to blow out the evap hoses or you’ll be back to the same problem.
  11. Mar 13, 2020 at 4:41 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Check/replace the vent hoses before you throw more $$$ at it. Overfilling can cause charcoal to float out thru vent hoses clogging them up as it dissolves somewhat. Checked for cel codes yet? P0446 is common here... https://www.samarins.com/diagnose/p0446.html
  12. Mar 13, 2020 at 5:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wonder if there is a way to just bypass the canister and have a vent?
  13. Mar 15, 2020 at 7:03 AM
    haggis444
    Cincinnati
    Well...Took a 4 hour drive, close to the end the gauge said less than 1/4 tank which in Toyota land meant it probably still had 1/2 tank. Stopped @ a Weigel's and filled up fine. SMH.
  14. Mar 15, 2020 at 7:05 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Funny how since this thread my truck has done this every fill up. If im over 1/4 tank, pump clicks and clicks. I’m going to unplug the canister to test venting
