Garage doors?
Discussion in 'Home Improvement' started by Ps3udonymous, Jul 2, 2019.
Professional or DIY?
Poll closed Jul 30, 2019.
  1. Pro
    9 vote(s)
    75.0%
  2. Diy
    3 vote(s)
    25.0%
Multiple votes are allowed.
  1. Jul 2, 2019 at 9:13 PM
    Ps3udonymous
    Ps3udonymous [OP] Who is the smart ass that changed the title?
    Question about a garage door. Mine has a big ass spring on the top that I assume reduces the work the electric motor is going to do.
    One thing I've noticed is the door will fall closed by itself when released from the carrier that rides on the chain.
    Question would be, how difficult would this be to do myself? All I need to do is add more spring tension...
  2. Jul 2, 2019 at 9:38 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    Yes. The springs often weaken over time and need adjustment. They can be very dangerous if u don’t know what ur doing. Unplug opener, lower door, and pull emergency cord to disengage the slide from trolley. If u have what I think, it will be a coil spring wrapped around a rod running the width Of the door with cable running down the door on each end. Attached to the spring there will be a round adjusting cone with several holes and a couple bolts that peg the rod the spring is wrapped around. I recommend searching up some YouTube videos and watching them throughly. The door should be in the closed position when making adjustments. When properly adjusted, the door should stay in place when opened half way and little force is needed to lift it. You will need two 1/2 rods inserted into the slots of the adjustment cone. Two is necessary. One for holding tension while you relocate the other rod in next hole to adjust. Watch the video here. Don’t stand in the path of the rods while adjusting in case a rod slips in your hand. These springs are wound tight and can go ballistic if not careful. Tighten the peg bolts before removing and rods to lock the spring in place.
    https://m.youtube.com/watch?v=KiZvXfMCmgs
    Omohundro likes this.
  3. Jul 3, 2019 at 12:04 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    This
  4. Jul 3, 2019 at 12:07 AM
    Omohundro
    Jody
    McMinnville TN
    Let me add you are the only one that knows your mechanical ability. Me, I would tackle this all day, my brother would tear the house down.
  5. Jul 3, 2019 at 3:22 AM
    Ps3udonymous
    Ok, this made sense. I figured that's what needed to be done, I just wasn't sure how special the equipment was, or if there was some type of method/ something I needed to pay attention to.
  6. Jul 3, 2019 at 3:24 AM
    Ps3udonymous
    I'm quite handy. Well, handy enough to eff it up until I figure it out.
  7. Jul 3, 2019 at 3:45 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’ve never done this myself, but have heard all my life to never mess with garage door springs. Apparently they are lethal if they come loose on you, so best to hire someone.
  8. Jul 3, 2019 at 4:37 AM
    Ps3udonymous
    This was my thought as well. But after looking at it closely, it doesn't seem too hard. At least not hard enough to pay someone to come and loosen the two or three set screw locking the spring assembly to the shaft and winding the spring tighter.
    I'll be watching some you tube videos, and grabbing a 30 rack and going for it more than likely.
    War Machine[QUOTED] likes this.
  9. Jul 3, 2019 at 5:20 AM
    Jas4tundra
    Jas4tundra New Member
    Jasmeet
    2019 Tundra limited white
    Stock
    Just be careful those things are nasty , if old more than likely to break
  10. Jul 3, 2019 at 5:27 AM
    Omohundro
    Jody
    McMinnville TN
    It’s all about having the proper adjustment rods and taking your time, having two people may not hurt either.
    Ps3udonymous[OP] likes this.
