Fuel Tank Question
Discussion in '3rd Gen Tundras (2022+)' started by Keepontrying, Jan 16, 2022.
  1. Jan 16, 2022 at 7:56 AM
    Keepontrying
    Keepontrying [OP] New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Looks as if the small tank comes with a SR5 Crewmax 5.5 ft. but you can get a package that gives you the 32 gallon tank?
    Is the 32 gallon tank standard with the SR5 Crewmax 6,5 ft. bed? I didn't see it in any of the option packages, so assumed it is standard?
    Thank you!
  2. Jan 16, 2022 at 8:05 AM
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Yes, you doth assume correctly....and the 32 gallon tank is standard on Limited and up offerings.
    The "convenience package' adds the 32 gallon tank where it isn't offered standard.
  3. Jan 16, 2022 at 8:15 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    No not standard on any sr5 trim. Only with the convenience package.
  4. Jan 16, 2022 at 8:38 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    My SR5 TRD sport crew max is getting the 32 gal tank since I got the Advance Tech package.
  5. Jan 16, 2022 at 8:49 AM
    mountaingroan
    North Idaho
    Incorrect, standard on SR5 6.5 and CM. The 32gal isn't even in the Convenience package because it's standard on that larger truck.
    pablito88562 likes this.
  6. Jan 16, 2022 at 10:41 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I second that. When I was building one (CM6.5). I wanted to make sure I got the 32gal tank. Could not find a package with it. Then in the summary, it was listed.
    mountaingroan likes this.
  7. Jan 16, 2022 at 11:53 AM
    Keepontrying
    da Burgh
    Thanks it is confusing as i did not see it in any package for the 6.5 but it was in a package with the 5.5.
  8. Jan 16, 2022 at 11:58 AM
    Keepontrying
    da Burgh
    Going Monday to place the order.
    MTRock likes this.
