Fuel Gauge Sticking
Discussion in '2.5 Gen Tundras (2014-2021)' started by gm125800, May 16, 2018.
  1. May 16, 2018 at 1:48 PM
    gm125800
    gm125800 [OP] New Member
    2018 GMC Sierra Denali
    It appears I have encountered another electrical gremlin:(
    Has anyone had their fuel gauge stick? I've had this happen twice so far. I stop by and pump a mere 29 Gallons of fuel at a local Exxon in North Dallas. I hop in, go about my way and glance at my cluster. The cluster is showing slightly over half a tank when i topped it off. Miles to empty started at 400+ miles but is quickly dropping. I make it home, (no smell of fuel leaking sensed), and the MTE ends up at 340 miles. Google Maps states its 35 miles from the fuel station to my place. I get that the MTE is rarely accurate but will the fuel needle issue be something the stealership can diagnose? These days, they barely want to touch if there's no Check Engine light on.
  2. May 16, 2018 at 1:55 PM
    '14 here, no issues, I'd take to dealer take pics or video of it n show em
  3. May 16, 2018 at 1:56 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I think if you take it in with a full tank of gas an the needle is barely above mid-point, I think they need to address CEL or no CEL.
    NewImprovedRon and 15whtrd like this.
  4. May 16, 2018 at 5:53 PM
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
    My 2003 tundra would get stuck but it was because dust got inside the dash and would make the needle stick. All you had to do was tap the dash and it would move. No issues on my 2015.
    On a 2017, definitely take it in and have them fix it.
    NewImprovedRon likes this.
  5. May 16, 2018 at 5:55 PM
    Sounds like a stuck float sensor or whatever it’s called.
    NewImprovedRon and Ike74 like this.
  6. May 16, 2018 at 6:00 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Take it to the dealer and have them ohm out the sending unit in the tank. Bet it's faulty, but it will be warranty work.
  7. May 16, 2018 at 8:22 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Warranty. Keep us updated and good luck.
  8. May 17, 2018 at 3:30 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Take it to dealer like others said. With a full tank they will take bed off or loosen bolts and raise drivers side to access sender if that is what it is.
  9. May 8, 2020 at 6:13 AM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Reviving this thread lol just caught my needle stuck under 1/4 tank, you said you tapped the dash? Where? Toyota mentioned a “fuel sender” by the quarter panel. Going to get strong enough magnet and see if that moves it. Got an 01 btw..
  10. May 8, 2020 at 10:52 AM
    SilverRider
    Las Vegas
    After filling up I would give it a couple of whacks there and the needle would move back up.
    You can see dirt inside so I just assumed that was the cause.
    My brother is driving it now and still works.
    MrAristo likes this.
