Front Suspension
Discussion in '2.5 Gen Tundras (2014-2021)' started by jerryWRose, Oct 4, 2021.
  1. Oct 4, 2021 at 4:29 AM
    jerryWRose
    jerryWRose [OP] New Member
    Jerry
    2020 Tundra 4x4 SR5 Double Cab
    Aftermarket front and rear bumper with a winch
    I have a 2020 Tundra 4x4 SR5 Double Cab with the TRD Off-road package. I just had an aftermarket front bumper and winch installed that added about 200 lbs to the front end.
    Do I need to make any type of adjustments or upgrades to the front suspension?
    Thanks for the help.
  2. Oct 4, 2021 at 4:37 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    200 lbs. is quite a bit of extra, added weight up front. I would look into stiffer coil springs to compensate, or you are going to have extra nose dive over bumps and when braking. The added weight will probably also reduce shock life up front as well. Lots of options out there to remedy this.
    2mchfun likes this.
  3. Oct 4, 2021 at 5:46 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Fat Bob's Garage Vated adjustable coil overs would suit you well. I run them with a Ranchhand bumper, and drawtite front hitch on my 21
