Front Shock/Strut Replacement at 77k miles?
Discussion in 'Suspension' started by dwatts222, Apr 8, 2020.
  1. Apr 8, 2020 at 11:52 AM
    dwatts222
    dwatts222 [OP] New Member
    Daniel
    I have been having a small wheel wobble at 65 mph. I went in to get my alignment and balance fixed. The mechanic suggested that I was due for new front shocks and struts in the near future, as the heavy weight of my 2015 Crewmax had pretty much worn out the stock shocks/struts in 77k miles.
    Is he just blowing smoke and trying to upsell me? Or, should I take this enabling invite to finally make my truck more offroad worthy?
  2. Apr 8, 2020 at 11:53 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    No. Replace them. I bought my truck with 84k miles, original shocks. They are shot. Two of them are leaking oil.
    And yes, if you want better off road performance, now is the time to do it.
  3. Apr 8, 2020 at 11:57 AM
    dwatts222
    Daniel
    @JLS in WA thanks for the quick response. I will start shopping around now.
  4. Apr 8, 2020 at 12:01 PM
    JLS in WA
    You bet. I'll warn you, shopping is a never ending maze of rabbit holes. Establish your budget, do some research, and don't be afraid to make a phone call or two. I found the guys at Wheeler Off Road to be very honest without trying to upsell me. Here in few weeks I'm going to pull the trigger on the Eibach Pro Truck struts, coil springs, and rear shocks, and the Icon expansion pack for my rear springs.
    SC_TRD and zachzap361 like this.
  5. Apr 8, 2020 at 12:02 PM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    Boss offroad is having a great sale on 6112's assembled. I got my set from them. Great improvement for the Tundra and great customer service.
    zachzap361, Casper3 and Tundyfundy like this.
  6. Apr 9, 2020 at 6:24 AM
    Bigbird57
    Bigbird57 New Member
    +1 on 6112. Mine are set at 1.9"
    Casper3, Luckydog and Tundyfundy like this.
  7. Apr 9, 2020 at 7:38 AM
    NWPirate
    Zach
    WA
    +2 on 6112's set@ 1.3. Night and day over the 5100's
    Casper3 likes this.
  8. Apr 9, 2020 at 8:19 AM
    dwatts222
    Daniel
    All, thank you for the feedback. Shopping around and getting some quotes today.
    NWPirate likes this.
  9. Apr 9, 2020 at 8:31 AM
    NWPirate
    Zach
    WA
    For what it's worth, my old 2015 NON-TRD 4x4 tundra had a leaking rear shock @ 50k miles. I believe those were the cheaper factory black Bilstein shocks??
    Anyone, feel free to correct me on the brand
  10. Apr 9, 2020 at 8:50 AM
    Bigbird57
    Look for about$600 for the 6112's unassembled.
  11. Apr 9, 2020 at 8:56 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    +3 on bilstein 6112s. Awesome suspension that really soaks up the bumps. 10/10 would buy again
  12. Apr 9, 2020 at 9:06 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    My 2015 Limited shocks were shot all around by 80,000 miles. They were the stock black Tokicos. Rode horrible as one of the rears had no rebound and both front were leaking. Replaced rear with Billy 5100s and front with 6112s at 1.3". Night and day. Just hope they last.
  13. Apr 10, 2020 at 4:38 AM
    dwatts222
    Daniel
    For those that went with the 6112s (@Dano8855, @Bigbird57, @NWPirate, @Sumo91, @Trikerider):
    1. Is it a "must" to replace the UCAs with the front shocks? I plan to follow your lead here and only set a small lift in the front, and I (sadly) drive very little off road right now.
    2. Stupid question- should I get unassembled or assembled 6112s? @Bigbird57 mentioned a price point on unassembled.
    3. After getting some quotes from local shops, this is feeling more and more like a DIY project. If any of you went the DIY route, would you still recommend DIY? I've seen some helfpul youtube videos, but I can see how this would lead to cussing and maybe throwing a wrench down.
  14. Apr 10, 2020 at 5:13 AM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    Definitely hit up boss-off-road, they have helped me out tremendously over the past few weeks and will continue to go to them for anything.
  15. Apr 10, 2020 at 5:15 AM
    Trikerider
    2015 Limited CM
    1. Kept stock UCA, no issue but I kept the tire size the same width, went slightly taller. No issues that I was told of aligning.
    2. I got unassembled as they were cheaper, and a local 4x4 shop assembled and installed.
    3. I just didn't have time to do the install myself, I did the rears myself. I had the shop install the 6112s, I ran them for 2 weeks and then had them mount the new tires and align after things settled.
  16. Apr 10, 2020 at 6:39 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    1. if you are staying close to stock size tires, then yes you can keep the same UCA. I went to a 33" tire and everything is fine.
    2 this is your preference. I got mine from boss off road assembled. It was easier for me to do that and then install them. BTW boss off road is a having a kick a$$ sale on assembled 6112's.
    3. it depends on your level of skills. It takes a little bit of time and patience, but it is very doable in the driveway. Like you said, there are several video's out there than can give you an idea of what your're getting into. Few cold beers also helps.
  17. Apr 10, 2020 at 7:35 AM
    NWPirate
    Zach
    WA
    I bought unassembled and had a local off-road shop install mine also, stock uca's and I went 1.3 lift to keep a little factory rake for towing.
    Still running the stock tires but plan on 275/70's soon.
    Hope this helps, enjoy!
  18. Apr 10, 2020 at 7:50 AM
    NWPirate
    Zach
    WA
    4 settings for lift and a better ride.
  19. Apr 10, 2020 at 7:54 AM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    Ok I missed the lift part. I’ve tried the 5100 experience on a Seirra and wasn’t impressed with the stiffer ride.
  20. Apr 10, 2020 at 8:01 AM
    NWPirate
    Zach
    WA
    Yeah I had the 5100's on a Ram 1500 and was not happy with the ride.
    6112's are a big improvement
  21. May 31, 2020 at 8:30 AM
    dwatts222
    Daniel
    Update-- Boss 4x4, Wheeler's, and Headstrong all had great customer service. I cheaped out a little and went with Eibach Pro 3/1 all the way around. I read the reviews on them not being exactly 3" but wasn't really phased by that issue. I set them on the second notch and the truck is pretty much dead on level. Very happy with the ride quality, handling, and lift as a result. Will step up to the 6112/5160s next time around. Thanks to all for the helpful feedback.
    EDDO likes this.
  22. Jun 5, 2020 at 5:21 PM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    dwatts222[OP] likes this.
  23. Jun 6, 2020 at 5:38 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I replaced mine around 40k miles. I never liked the stock, black shocks. I replaced them with Fox 2.0 coil overs and Fox 2.0 in the rear.
  24. Sep 2, 2020 at 12:16 PM
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    How do you like them?
