Front End Steering/Suspension Rebuild
Discussion in '1st Gen Tundras (2000-2006)' started by MNtundra, Jan 1, 2021.
  1. Jan 1, 2021 at 10:18 AM
    MNtundra
    MNtundra [OP] New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Going to do a Front End Steering/Suspension Rebuild
    What main steering / front end suspension parts should be done when tackling a complete over haul? There is nothing I hate more than redoing the same work twice. I should have tackled all this when I had my 5100’s Installed... Help me compile a list of parts I should replace.
    • Front Upper Ball Joint - Qty 2
    • Front Lower Ball Joint Passenger Side - Qty 1
    • Front Lower Ball Joint Driver Side - Qty 1
    • Front Outer Tie Rod End Passenger Side - Qty 1
    • Front Outer Tie Rod End Driver Side - Qty 1
    • Front Inner Tie Rod End - Qty 2
    • Bilstein Shocks - Qty 2 (DONE)
    • Front Wheel Bearings
    • Front CV Axles
    Additional Considerations?
    -Steering knuckle or shaft seal or bushing?
    -UCA’s?
  2. Jan 1, 2021 at 10:33 AM
    Professional Hand Model
    Hand Protectors
    SPC Cams Bolts
    Maybe New OEM CV Axles (or do a rebuild on existing prior to total work done at shop with High Dolla Alignment)
    New front bearings if you want to spend $
  3. Jan 1, 2021 at 1:28 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Steering rack bushings, sway bar links, and frame side sway bar bushings.
    New lower control arms, maybe upper if you aren't happy with your alignment numbers.
  4. Jan 1, 2021 at 1:32 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I thought the inner tie rods on our trucks were part of the racks, not sold separately?
  5. Jan 1, 2021 at 1:37 PM
    Hand Protectors
    New WL13 (slightly larger) Brake Calipers and Shoes if yours are original. Might as well go all in and get it over with.
  6. Jan 1, 2021 at 2:09 PM
    MNtundra
    Tony
    Minnesnowta
    Yes you can buy inner tie rods only @FirstGenVol part # 45503-09120
    @Professional Hand Model Overhauling/upgrading the entire brake system will be next project... if I do buy a sway bar, do The sway bar links replace the outer tie rods? Also, do I want a front, rear or both sway bars? Addco or hellwig?
    I am loving the snowflakes & 275/70/17 BFG’s. Only frame rub at full chock...
  7. Jan 1, 2021 at 2:12 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Unless it's been removed all the trucks came with a front sway bar.
    Links and tie rods are different parts.
    Tundra2 and MNtundra[QUOTED][OP] like this.
  8. Jan 1, 2021 at 2:21 PM
    Hand Protectors
    I’m partial to the Rear Hellwig as its thicker/stouter, but its also more expensive than the Addco one which looks more stealth being mounted in front of the axle.
    My Front Sway is OEM. I think the end links parts are separate from the tie rods in that both are needed. Hellwig is Made in USA. Unsure of Addco.
    You’ll love having both if you are street driving. Changes the entire handling for the better. Surprised more members don’t have them. Truck is tight!
  9. Jan 4, 2021 at 10:49 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    03 Tundra AC TRD
    I would consider UCA bushings or SPC UCAs if they are worn/old.
  10. Jan 4, 2021 at 11:34 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Be prepared to have to cut the control arms off right @Tundra2 ... Then you will need to do the bushings or buy new arms.
  11. Jan 4, 2021 at 12:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, correct.
    Diablo thick metal sawzall blades.
    Napa Lower Arms. I'll compile a list of links for everything I used on my truck.
    I don't see why the V8 would be different than V6 as far as cam sleeves, etc. You do have the CV axle in the way, and need to watch out for.
  12. Jan 4, 2021 at 12:20 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    You mean the Diablo carbide blades right? I have never found anything comparable to those.
  13. Jan 4, 2021 at 2:55 PM
    Hand Protectors
    I found some Diablo Blades on the street corner today. Score!:yes:
    Stuck in the '00s likes this.
  14. Jan 4, 2021 at 3:16 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I love street tools. Nice find.
  15. Jan 5, 2022 at 2:51 PM
    T2ndLife
    T2ndLife New Member
    JD
    '02 4.7L 225K 4WD Ext Cab
    WIP - keeping stock Kenwood DNX9960 GPS Nav/Stereo NexD XD400/4 400W Amp Wood Trim package added 4Runner alloy 17 inch wheels
    @Tundra2 Hi, a bit late to the conversation, but in a similar situation a year later as MNTundra. Did you ever assemble a list?
    thanks
