Front end creaking/rubbing noise
Discussion in '3rd Gen Tundras (2014+)' started by dusted_tundra, Aug 12, 2019.
  1. Aug 12, 2019 at 6:28 PM
    dusted_tundra
    dusted_tundra [OP] New Member
    Samuel
    2015 Toyota Tundra SR5 Crewmax
    Icon Stage 5 Suspension Toyo AT 2 Xtremes 35s 18” method Race Wheels
    Noticed that I have a creaking/ rubbing sound on my front end. I caught it one time about to pull out of my parking spot. I had my girlfriend wiggle the steering wheel and the noise was coming from the drivers side tie rod. Any ideas?
  2. Aug 12, 2019 at 7:06 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    If the hardware isn't tight on my skid plate it creaks going over bumps
  3. Aug 12, 2019 at 7:08 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    2020 Limited DoubleCab
    Check your lower ball joint for leaks.
  4. Aug 13, 2019 at 7:27 AM
    dusted_tundra
    Samuel
    I do not have a skid plate however I do have some leakage on the lower ball joint. I jacked the wheel up and there is no play. Should I add grease or replace?
  5. Aug 13, 2019 at 7:53 AM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    I have a squeak which seems to be coming from my lbj. I’m going to try shooting it up with grease this weekend. If that doesn’t work I’m going to swap out my lca. I’ll let you know how it goes.
    dusted_tundra [OP] likes this.
  6. Aug 13, 2019 at 2:03 PM
    dusted_tundra
    Samuel
    I don’t get home till Friday. I just bought a pro eagle jack, now I can finally lift up both wheels off the ground I keep you posted on the findings
    joonbug likes this.
  7. Aug 16, 2019 at 12:19 PM
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
    Following. I have a squeak too
  8. Aug 17, 2019 at 1:22 PM
    dusted_tundra
    Samuel
    Update: I jacked the front end up and wiggled both wheels with the truck off. Nothing seems loose and I have no play or noise besides the steering wheel inside the cab locking . I turned the truck on, manually turned the steering wheel by grabbing one wheel and turning it with both hands(while under the truck). There is no hitting or creaking, or rubbing noise then. So then I lower the truck and have my GF turn the wheel. Once I turn left a bit that’s where the noise come back. So I go under the truck and grab both tie rod ends and feel/hear that the noise is indeed coming from there. I’m wondering if I should add grease to the ends
  9. Aug 17, 2019 at 1:26 PM
    dusted_tundra
    Samuel
    I’m gonna look up on how to grease these and I’ll keep you guys posted
    georgiey22 likes this.
  10. Aug 17, 2019 at 1:29 PM
    dusted_tundra
    Samuel
    Running icon Stage 5
  11. Sep 6, 2019 at 10:30 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Tundra TRD nonPRO
    Methods, Toyos, Kings, TCs
    Those tie rod ends are not a serviceable part. If they were, they would be a zerk on the opposite side of the stud. However, you CAN grease them, but you must remove the boot and pack the ball then reinstall the boot. I'm thinking though, that if you have to do this, then the boot is damaged or the seal is damaged anyways and you need to just replace the part. Otherwise it'll happen again. If you replace them with a serviceable rod end with a zerk fitting, just add it to your grease schedule.
    Are those ICON UBJ's serviceable? I know they're capped, but are you supposed to lube them ever? My old Camburg arms needed non-silicone lube every couple weeks or they'd squeal over bumps.
    1fujifilm and dusted_tundra [OP] like this.
  12. Sep 12, 2019 at 12:20 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Had a similar noise from the front end. Thought my steering was going out! Ended up being my Uniball in the UCA. Add some Tri-Flow dry lubricant. Mine went away almost instantly. Make sure the uniball is clean from dirt and dust also.
  13. Sep 13, 2019 at 6:27 AM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    Yup, if your gonna invest the labor, you always invest in the part.
    Bear
  14. Sep 13, 2019 at 8:43 AM
    dusted_tundra
    Samuel
    Yeah, I did a big bear off-road trip recently and it was super loud. So I figured it was due to the dirt. I forsure will lube them up soon
    Tundyfundy likes this.
  15. Sep 13, 2019 at 8:45 AM
    dusted_tundra
    Samuel
    Here some cool shots
    TheBeeGuy and Tundradrenalin like this.
