Free: 27mm front sway bar.
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by assassin10000, Jun 4, 2021.
Thread Status:
Not open for further replies.
  1. Jun 4, 2021 at 7:11 PM
    assassin10000
    assassin10000 [OP] New Member
    Andrew
    Northern CA
    '05 SR5 AC
    27mm front sway bar, OEM for 03-06 Trucks and Non-sunroof Sequoia's.
    An upgrade for early model (99-02) 1st gens.
    It's the bottom/dirty one in this pic:
  2. Jun 4, 2021 at 9:15 PM
    HotRodMatt
    HotRodMatt New Member
    2001 Access Cab Limited TRD
    Where are you. I’m in Salinas
    Is this an upgrade for A TRD 2wd AC?
    I’m gonna be in alameda on Sunday for the antiques fair
    matt
  3. Jun 4, 2021 at 9:59 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I'm in Sacramento.
    It will be if you currently have the smaller 23/24mm bar.
  4. Jun 4, 2021 at 10:17 PM
    HotRodMatt
    Damn! I was In Sacramento last weekend! I’ll have to see when I can get up there next. My grandmother in law lives up there.
  5. Jun 12, 2021 at 3:30 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Too bad I didn't have this available then. :notsure:
    Well, I may be able to bring it with me to the bay area. I have family there I visit ever month or two.
  6. Jun 12, 2021 at 7:57 PM
    HotRodMatt
    I’m sure I’ll get up to sac some time soon. We’ll make it happen I confirmed I have a 24 mm today so I’m definitely down
    matt
  7. Jun 18, 2021 at 12:34 AM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    Hi I’m in sac and have an 02 ac. I’d love to pick up the bar when you’re available. I will pm you
  8. Jun 18, 2021 at 2:25 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Any idea of when? It may be worth grabbing from a junkyard closer to you. I think they're less than $40 and at these gas prices...
    Matt is currently first in line for it.
  9. Jun 18, 2021 at 8:20 PM
    HotRodMatt
    i would if i could find a junkyard with a tundra or sequoia in it. the one closest to me is in rancho cucomunga. right by you!
    very gentlemanly of you to put me first in line but i fear it will be some time before i get up there. feel free to let DaWhiteTundra pick it up so your not tripping over it!!
    thank you Andrew, your a good egg!
    matt
    DaWhiteTundra likes this.
  10. Jun 19, 2021 at 9:46 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    No problem.
    Just did a quick search. Apparently there is one in Salinas. Maybe worth a look.
    If it's there it'd be a good pairing with a 19mm rear bar like the addco one IMO.
    https://www.tundras.com/threads/inexpensive-but-capable-rear-sway-bar.82902/
    I put a 21mm rear bar on and it was a bit too much for the 27mm front, so I upgraded the front too.
  11. Jun 19, 2021 at 1:10 PM
    HotRodMatt
    bro i check that yard on row 52 all the time, just haven't been looking the last two weeks as ive been working on a CRV project for my better half!
    you rule, i went by and it was almost completely gutted though. passenger access cab door was there and the dash thast about it. almost grabbed the rotors.....
    sway bar had already been removed. with a saw no less...
    buuuuut what is that on the rear frame, under the fender liner?
    BAM, mission success, thanks for the heads up. also got a super tight and smooth steering shaft ( i think mines got a slight clunk, so i bought it before they scrapped it), and a front skid plate which was missing on mine when i bought it (old accident)
    thanks a lot man, big score! all for the grand total of 70 bucks, and a free scrap of headliner to practice cutting holes in to add a Volvo home link module.
  12. Jun 23, 2021 at 11:46 AM
    DaWhiteTundra
    Anthonee
    Sacramento, Ca
    Thanks man
  13. Jun 23, 2021 at 12:31 PM
    DaWhiteTundra
    Anthonee
    Sacramento, Ca
    Thanks again Andrew! Nice meeting you man. I’m definitely going to have to come by for a real alignment.
    Im going to lower the setting of my 5100’s when I find some new to me tires later this summer or fall.
    do you have the addco rear bar too? When I was sitting out front it looked like your Bar was mounted behind the diff. I have the addco and I put mine above the front of the diff. Did I install mine on the wrong side lol?
  14. Jun 23, 2021 at 2:54 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Nope.
    I retrofitted one from another Toyota using a mix of some weld on diff brackets, end brackets I made out of some 3/16 flat bar and end links off another Toyota.
    DaWhiteTundra[QUOTED] likes this.
Thread Status:
