Fox coilovers and strut spacer
Discussion in 'Suspension' started by Tchapman1998, Dec 14, 2018.
  1. Dec 14, 2018 at 5:26 PM
    Tchapman1998
    Tchapman1998 [OP] New Member
    Tristan
    2007 black tundra SR5
    8.5 inch lift 37 13.50 18 Moto metal MO962 18x10 -24 4.88 rear end
    I am wanting to get fox 2.0 coilovers but I can't find any for an 8.5 inch lift, has anybody put a 6 inch strut spacer on top of the 2.0 coilover?
    Y0TA PR0 likes this.
  2. Dec 14, 2018 at 5:26 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Dec 14, 2018 at 5:27 PM
    Tchapman1998
    Tristan
  4. Dec 14, 2018 at 6:07 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    2.0 shocks are way too small for a truck this size. Minimum should be 2.5.
    It really kind of depends on the amount of money you want to spend. You can find a full coilover that is built for your lift, or you can go the less expensive route and simply use the supplied spacer on the factory strut ( assuming your current lift kit came with one)
    Black Wolf likes this.
  5. Dec 14, 2018 at 6:13 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Fox makes a coilover for the BDS 7" lift, and I know for sure it can be cranked to 8" (might be able to crank it to 8.5") or you could leave it at 7" and run a small spacer on it.
  6. Dec 14, 2018 at 6:40 PM
    Tchapman1998
    Tristan
    So should I get the bilstein 6112's?
  7. Dec 14, 2018 at 6:57 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    No
  8. Dec 15, 2018 at 1:12 AM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    Go with the BDS 7” kit. Crank it up and roll.
  9. Dec 15, 2018 at 3:54 AM
    tmart
    tmart New Member
    Travis
    I have fox 2.5s with RR on my BDS 7 inch. No spacer needed
