Found that noise!
Discussion in '1st Gen Tundras (2000-2006)' started by Cacoleman2014, Jul 17, 2019.
  1. Jul 17, 2019 at 1:05 PM
    Cacoleman2014
    Cacoleman2014 [OP] New Member
    Louisiana
    2006 Tundra SR5 double cab
    Finally found the noise coming from the rear end! Wheel bearings are toast! Since I have the axels out I was going clean up the diff. Anything I should be looking for or should pay attention to when I open it up My first time!:fingerscrossed: Also, suggestions for lsd fluid. Got 179000 and I don't know about previous service
  2. Jul 17, 2019 at 1:12 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    *insert gratuitous fart joke here*
    TXMiamiFan, Darkness, bmf4069 and 2 others like this.
  3. Jul 17, 2019 at 1:20 PM
    Aerindel
    Aerindel New Member
    Montana
    What kind of a noise was it?
  4. Jul 17, 2019 at 2:07 PM
    Cacoleman2014
    Louisiana
    Definite grinding and vibration. Tried to spin after I removed axel and it grinds and stops as soon as you let go! I was scared to drive it,.
  5. Jul 17, 2019 at 3:35 PM
    Professional Hand Model
    Hand Protectors
    Good on ya.
    Black Wolf likes this.
  6. Jul 18, 2019 at 5:28 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    I would personally not mess with the diff. Just drain and refill the fluid!
    FirstGenVol likes this.
  7. Jul 18, 2019 at 6:25 AM
    Cacoleman2014
    Louisiana
    There was a little bit of a metallic sludge in the first bit of fluid that came out. Wanted to do a good cleaning and flush to get it all out before I put new fluid in.
  8. Jul 18, 2019 at 10:20 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I don't know that there is a good way to really flush it out. Since diff fluid is relatively cheap you could a drain+fill now and then do it again in a month or so. That's the approach some of us have been taking on our transmission fluid.
    bmf4069 likes this.
  9. Jul 18, 2019 at 2:50 PM
    Cacoleman2014
    Louisiana
    Decided to do just that. I put about 25000 miles a year on my truck. Mostly highway miles, but I do pull a camper that gets pretty close to the top end of my weight. Any suggestions on lsd fluid?
  10. Jul 24, 2019 at 9:41 AM
    Hand Protectors
    Squeeze some new fluid into the fill hole and watch it wash the last little bits out of the drain hole. Plug and fill and the magnet will do its job.
