Footwell bulb removal?
Discussion in 'Lighting' started by Baja1000, Feb 17, 2019.
  1. Feb 17, 2019 at 7:36 AM
    Baja1000
    Baja1000 [OP] New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    Any trick to removing the bulb
    By the footwell? I have a VLEDS
    adapter so I can install some LEDS.
    2018 TRD
    Thanks
  2. Feb 17, 2019 at 7:38 AM
    Baja1000
    Andy
    SOCAL
  3. Feb 17, 2019 at 7:44 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    You should be able to grab the bulb with either a pair of needle nose(wrap the tips with duct tape sticky side out), or by just grabbing with a piece of duct tape itself.
    TXMiamiFan and Pudge like this.
  4. Feb 17, 2019 at 7:52 AM
    Baja1000
    Andy
    SOCAL
    Great thanks
  5. Feb 17, 2019 at 7:53 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I just reached behind the panel and removed the bulb socket, then you can just grab the bulb with your fingers.
  6. Feb 17, 2019 at 7:57 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Before removing the bulb, you’ve gotta get behind there with your fingers and turn the bulb socket about a 1/4 turn and it’ll come out from behind.
  7. Feb 18, 2019 at 11:40 AM
    Baja1000
    Andy
    SOCAL
    Got it and blew the fuse!
  8. Feb 19, 2019 at 7:20 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Why did the fuse blow?
  9. Feb 20, 2019 at 5:53 AM
    Baja1000
    Andy
    SOCAL
    On the adapter I bought the two leads were not making a good connection. So I bent them out a little and it plugged in and worked fine.
  10. Feb 20, 2019 at 5:56 AM
    Baja1000
    Andy
    SOCAL
    From the adapter I cut the other end off and cut and spliced my own LED light strip from eBay. I strung it through to the passenger footwell as well. It turned out great and it lit the place up. Very easy!
    SiberianTundra likes this.
  11. Feb 20, 2019 at 9:20 AM
    SiberianTundra
    Greg
    War Machine
    what were the LED strips you purchased ?
  12. Feb 20, 2019 at 12:55 PM
    Baja1000
    Andy
    SOCAL
  13. Oct 30, 2019 at 6:46 PM
    biebs96
    PA
    Do you have a picture of this? I have an extra led strip and this would be a good idea
  14. Oct 30, 2019 at 7:43 PM
    SiberianTundra
    Greg
    War Machine
  15. Jan 19, 2020 at 3:00 PM
    SummerGS1
    SummerGS1 New Member
    Hey Baja, where did you get the foot well adapter?
  16. Jan 19, 2020 at 4:18 PM
  17. Apr 22, 2021 at 3:42 PM
    Triplehtown
    Triplehtown New Member
    Sorry to dig up an old thread, but I've gotten to the actual light install part. How did you get the lights from one footwell to the other?
  18. Apr 24, 2021 at 6:47 AM
    Baja1000
    Andy
    SOCAL
    Just feed them through. Once your down there you will see it’s a piece of cake.
    Did you look to VLEDS for any parts?
    My 3M backing wore off, so I had to make shift and just wedged them so that the lights are pointing down. This is by far one of the top 5 mods!
    Good luck
    Triplehtown likes this.
  19. Apr 24, 2021 at 11:35 AM
    Triplehtown
    Yeah, thanks bud! I cannibalized one of the vled adapters to make it easier.
  20. May 18, 2021 at 6:18 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Good info
  21. May 18, 2021 at 7:02 AM
    Baja1000
    Andy
    SOCAL
  22. May 18, 2021 at 8:48 AM
    Triplehtown
    I'll be doing this at some point in the future because I keep strapping waterproof boxes for tools underneath my tonneau. I wonder how hard it will be to tap into the existing leds so it turns on with the existing lights.
  23. May 28, 2021 at 9:37 AM
    Baja1000
    Andy
    SOCAL
    Not sure about that one. Probably not too bad
