Fog lights not working after 2018 headlight upgrade
Discussion in 'Lighting' started by Sas, Aug 31, 2018.
  1. Aug 31, 2018 at 12:04 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Just realized that my fog lights are no longer working after installing the 2018 headlights. I also have the NSV bar. I didn't have DRL's on my SR5 to begin with. They worked after installing the NSV bar, but lost them on the headlight upgrade.
    Anyone else come across this and/or have a suggestion on how to fix it? I'm assuming it's a wiring issue in the harness somewhere. I've checked the fog fuse under the hood and replaced just for a sanity check.
  2. Aug 31, 2018 at 1:06 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  3. Aug 31, 2018 at 3:43 PM
    Sas
    OKC, OK
    So here's an update on this. I've put everything back to stock, but the only way the fog lights come on is when the turn signal is on and then the fogs blink w/the turn signal. Does anyone have the factory wiring order for 3 wires?
  4. Aug 31, 2018 at 3:59 PM
    iHacker
    iHacker Well-Known Member
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    In order to use NSV bar with 2018 LEDs you have to follow the instructions for a Platinum/1794, don’t have to use the t-harness they include with the NSV bar.
    That t-harness (and probably you have the all the time fogs mod) is causing back feeding to the fogs wiring
    831Tun likes this.
  5. Aug 31, 2018 at 4:13 PM
    Sas
    OKC, OK
    That's not even hooked up anymore to the harness. The headlights and tail lights are on OEM harnesses and halogen bulbs. I even disconnected the resistors to both. I'm also running the stock headlights now as well.
    It's just the pinning on the OEM turn signal harness that had to be changed and I'm trying to put it back to stock pinning but I don't remember what it was.
    I don't have the all-the-time fog mod either. That'll get you a ticket in this state. I've never even touched the fogs.
  6. Aug 31, 2018 at 4:48 PM
    Sas
    OKC, OK
    So this combo is the only time the fogs come on and they blink with the turn signal. This is the driver's side. Pink is on the bottom, purple in the middle.
  7. Aug 31, 2018 at 4:58 PM
    Sas
    OKC, OK
    The weird thing is I don't get even get a dash light for the fogs either when I turn them on, but I get a continuity tone at the fuse when they're on. Is there another fuse for them somewhere besides under the hood?
  8. Aug 31, 2018 at 5:03 PM
    iHacker
    Stock pining for turn signals
    Is red/pink, white in the center and violet in the outer side
    Not at home to get you a better picture but the empty spot shown in the picture is for the violet wire
  9. Aug 31, 2018 at 5:46 PM
    Pudge
    CT
    I bet it's something to do with the NSV. I don't have one but they seem to be finicky and cause issues with any lighting upgrades, even just changing blinker bulbs
  10. Aug 31, 2018 at 5:51 PM
    Sas
    OKC, OK
    NSV isn't hooked up at this point. Just tested the relay. Didn't hear a click when turning on the fog lights from the stick, so pulled it and tested it. It was running ~170 ohms but it was clicking when power was put to it. I don't have a light tester to do the rest of the test tho.
    Still no go on the fogs working. Here's the current wiring.
    Driver:
    Passenger:
    I'm completely dumbfounded.
  11. Aug 31, 2018 at 6:21 PM
    Pudge
    CT
    Hmmm yeah I have no idea. Has to be a relay issue or something
  12. Aug 31, 2018 at 6:24 PM
    Sas
    OKC, OK
    I should clarify the NSV bar statement. It has power and is hooked up to its own panel, but isn't hooked into the OEM harness under the hood. The only place where it might have an issue is in the harness in the dash. So it looks like that's my next stop. Ugh. What a nightmare.
  13. Aug 31, 2018 at 8:10 PM
    Sas
    OKC, OK
    Thanks, I've changed them up. Can you confirm the connections for me?
    @csuviper you have any thoughts on this by chance? I've read a number of posts about this issue and so far haven't seen a solution (other than the hacky one that someone did with a bent relay tab, which isn't an option). What's really perplexing is that I can wire the turn signal so it triggers the fog lights to blink when the signal is turned on. I'm not sure why that's the only way power is getting to the fogs.
  14. Aug 31, 2018 at 8:15 PM
    iHacker
    Connections look good in the correct place
    Sas [OP] likes this.
  15. Aug 31, 2018 at 8:16 PM
    iHacker
    What kind of bulbs are you using in the fogs housings?
  16. Aug 31, 2018 at 8:23 PM
    Sas
    OKC, OK
    They're completely stock.
  17. Aug 31, 2018 at 8:42 PM
    iHacker
    Ok this clears the polarity thing, the only thing a can suggest at this point is if everything is stock, all fuses and relays OK, then the last option is to inspect the fogs switch all wiring to the stalk
  18. Aug 31, 2018 at 8:44 PM
    Sas
    OKC, OK
    Yeah, that's where I'm headed tomorrow. The NSV dash harness adapter is the only thing I can think of that's in-between the stalk and the fogs at this point.
  19. Aug 31, 2018 at 8:46 PM
    Sas
    OKC, OK
    It's weird. I don't get a dash light either, even when the fogs light up with the blinker. I'm not sure how that circuit is wired though.
  20. Sep 1, 2018 at 6:25 AM
    Sas
    OKC, OK
    I did a couple more tests this morning. I took the fogs out and tested them both directly from the battery to the connectors on the fog light housings and they both lit up. So it's not the fogs. I also tested the new Morimoto fogs the same way just to be sure they work before I install them. So the fogs can be ruled out.
    I also went back and did a voltage test on the fog light fuse as well. With the truck started, the headlights on and the fog light switch on I was getting no voltage. So I took the fuse out and tested continuity once again just to be sure, and it toned so the fuse is good. I also tested the connector at the end of the fog lights and was getting about 17 mV (millivolt) on each connector. I would think that would be zero, but maybe there's some residual voltage that is always sent down the harnesses by the ECU for testing?
    Correct me if I'm wrong, but if the fuse isn't getting power then it has to be somewhere between the stalk and fuse box yes? Where does the ECU sit in this circuit?
  21. Sep 1, 2018 at 7:50 AM
    Sas
    OKC, OK
    Okay, I think I may have found out what's wrong. Before tearing apart the dash I decided to see if I could find the specifics for the relay to officially rule it out.
    This is from the 2015 Tundra manual. I don't have the 2017 but I'm assuming it's the same.
    When measured, I'm getting 168.4 ohms, which is 0.1684 kΩ. That's far short of the 10 kΩ. Assuming I'm measuring this correctly, at this point I'm pretty sure it's the relay.
    That being said, the saga continues. The part # of the relay says 90080-87026.
    However, when I look that part number up over at ToCS it says that it's for a 2017/18 Tacoma and doesn't have the Tundra listed at all.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-relay-9008087026
    When I go to the related parts link for the fog lights it shows a different relay that doesn't have the same pin pattern. So I'm pretty sure that one is wrong too.
    https://parts.toyotaofcoolsprings.c...al-cat/fog-lamps-scat/?part_number=8121002160
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-relay-box-relay-9008087024/
    :annoyed:
    @Roman can you help me out here?
    If it is indeed the relay (crossing my fingers and praying to God at this point) I have to wonder what caused it to go bad in the first place (besides the fact that it could've been the incorrect one)? First things first though, I need to make sure I'm ordering the correct one before moving on.
    :fingerscrossed::pray:
  22. Sep 1, 2018 at 8:30 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Put a jumper wire between 3 and 5 on the socket. If the fogs turn on with headlights on the relay is def the problem.
    Sas [OP] and Pudge like this.
  23. Sep 1, 2018 at 8:51 AM
    Sas
    OKC, OK
    BlueBottle and Pudge like this.
  24. Sep 1, 2018 at 9:08 AM
    NewImprovedRon
    NewImprovedRon Hey! Get off my grass!
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
  25. Sep 1, 2018 at 9:12 AM
    Pudge
    CT
  26. Sep 1, 2018 at 10:25 AM
    Sas
    OKC, OK
    Well bummer, AZ doesn't have it in stock. So as soon as I hear back from Roman about that part I'll get it ordered and installed. With that additional verification step by @BlueBottle though, I think I can safely put everything back together now w/o fear of needing to take it apart again. Since I was going to upgrade the fogs to the Morimoto's and have some of the bumper off I figured I might as well take the rest of the thing off and platidip the chrome bumpers matte black while I'm at it. Aaaaand since I'm doing that I might as well match the rear bumper too lol. Gonna be a long day (and maybe tomorrow). Thankfully my OSU Cowboys already played Thursday!
    BlueBottle, NewImprovedRon and Pudge like this.
  27. Sep 1, 2018 at 1:35 PM
    Sas
    OKC, OK
    Oh holy balls. After soldering the resistors back on to the tail lights and doing a lighting test, I found that the brake lights were working but the tail lights wouldn't turn on. Thankfully it was just a blown "Tail" fuse in the box under the dash this time.
    Let my absent-mindedness be a lesson kids - NEVER disconn... no wait... ALWAYS disconnect the battery when monkeying around with electrical crap!
    NewImprovedRon, Pudge and TheBeast like this.
  28. Sep 1, 2018 at 2:39 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Amen!
  29. Sep 1, 2018 at 4:06 PM
    fisherman951
    fisherman951 New Member
    Tony
    2017 crewmax 4x4
    U did all ur swapping lights and splicing with battery connected? U one brave man.
    Motor71, Sas [OP] and Pudge like this.
  30. Sep 1, 2018 at 4:45 PM
    Sas
    OKC, OK
    Lol about half of the time I forgot to disconnect it. "Brave" is a very generous word.
    NewImprovedRon likes this.
